You have a link to that video?I saw one video where the cover was removed and there was a USB connection below the location for the charging pad. You may be able to connect any charging pad. I don't know the Ford part # for the factory charging pad.
What the heck is that?Does the wireless charging pad pop up easily? Is this mystery USB port under there?
I have no idea what video it was- the video was not about that specifically. He had the tray area apart in the video.You have a link to that video?
"drill through your airbags".....you gatta mic in my garage? hahahaOne could POTENTIALLY replicate the 1/4 20 GoPro mounting lug using this threaded brass insert. The bonus to this would be only needing access from the top side of the dash. I have not done this as i dont have a Maverick and this is just an idea. If you drill through your airbags that is on you.
https://www.boltdepot.com/Threaded_...uts_EPDM_rubber_with_brass_insert_1_4-20.aspx
I'm betting this is it, but to save money Ford should use just one wiring harness, but then again, this leaves it open for the aftermarket to make things so we can add to the Maverick.I would think that the power source for the Lariat charging pad would be there unless they use totally different wiring bundles on each trim level![]()
Maverick tax. Guess they just don't any ordering of parts. Damn D-Rings are $53 each.Not sure what's up with the >$500 MSRP for Maverick or why the part would be any different.
The lariat head lights don't just swap over to the xl... The harness is different. I think there might be quite a bit different between the different lvl trims wiring harnesses.I'm betting this is it, but to save money Ford should use just one wiring harness, but then again, this leaves it open for the aftermarket to make things so we can add to the Maverick.
Call me cheap if you want….but $571 for the Ford charging mat is a bit redonkulous. I found this on Amazon for about $25. Wouldn’t it do virtually the same thing??Ya that's a crazy amount of money for a wireless charging pad. I guess I will DYI. Thanks for the link.
