Requesting clerification on the wireless charing pad
ZABSMAV
Utah
2023 Maverick Lariat Hybrid
It’s standard in the 24 Lariat but I don’t use it because my phone gets extremely hot when on the charger pad. The dealer had no idea so I just don’t use it and use the charger cable.
Is your phone in a case?
AlsMaverick
Allen
Cincinnati
OP - don't despair, as the factory wireless charger is useless, anyway. I've owned 2 lariats and even with no case at all, it won't charge enough to even hold the battery % you start with, it just slows the drain a little bit. It's possible that this is better in MY25, but I wouldn't hold my breath - my '22 Bronco with Sync4 has a wireless charging pad that is just as ineffective as my Maverick.
this is especially true if you're using a wireless carplay / android auto dongle. (if you're wired, obviously, you don't need to wirelessly charge.)
if you need wireless charging, I'd search to see what others have done. Also I would not go cheap, there was a guy a few years ago who had a chinese wireless charging pad catch fire and burned his center console - he was lucky it didn't spread and burn the whole interior. (I thought I saved a pic of his fb post, but I can't find it. Trust me, it happened.)
I disagree with the assessment. The wireless charger in my '24 Lariat EB works perfectly fine for charging iPhone 13 Pro Max.
Ford Maverick Requesting clerification on the wireless charing pad 1740761130303-h1
You actually might be the first person to ever say that, the ineffectiveness is pretty well-known.
Maybe Ford finally fixed it in '24? Or maybe whatever it does works better with your phone.
Yes. being in a case will increase the resistance to wireless charging thus making things hotter.
Having to remove your case in order to obtain a better wireless charging connection is a bit much. VS
Leaving everything intact and plugging just your phone in.
I'd like to know, whose phone is not in the case now a days?
SLINGSHOT
Charles
NE Iowa
2017 RAV4
2023 Lariat Lux. Motorola cell phone with silicone case. Charger works fine. No overheating.
I know, I'm amazed too.
gbit3000
George
Midwest
Maveric 2025 Lariat AWD
My has it, still in built Lariat, but I rally I don't care for that, it degrading the phone battery, what I red about.
