remote oil draining....
JohnnyBravo
D
New York
225,000 mi. Honda CRV
is there anything new out there for putting a remote oil drain in so that big underside cover doesn't have to be removed?
bgillen35
Brendan
St. Cloud, Fl.
'24 Maverick XLT, '22 Indian Chief
The only oil change videos I've happen to see are with the FX4 and that giant metal skid plate that needs to be removed. I would imagine (or hope at least) that the hybrid (and I assume ecoboost) has an access panel for the drain/filter like every other sedan/suv with normal plastic undercovers.
ffjack15
Jack
Kansas City Mo
Honda
There's no access panel on the ecoboost to change oil it also has a cover.
bgillen35
Brendan
St. Cloud, Fl.
mavmav
Walter
New York
Maverick Hybrid 2022
entire plate does not need to be removed.
entire skidplate has to be removed from mav hybrid. let me know if you can change an oil filter without removing entire skid plate. cut the hole in a skidplate - is the only solution that i see.
Johnkn
MD
There is no “skid plate” on the Hybrid, LOL. There is a fiber cover.....
ShadowBlack XL440
Robert
Northern Ohio
There is no “skid plate” LOL. There is a fiber cover.....
Correct, but that fiber cover on the EB does have to be removed. That meas about 15 screws to remove. I have done it several times already.
mavmav
Walter
New York
it is still 15 extra screws to unscrew it. will extra hole harm aerodynamics? is the purpose of plastic cover for debris protection or for aerodynamic. aerodynamic ? ford pickup and aerodynamic? two incompatible things.
daddio211
Eric
St. George, Utah
Hot rods
I'm going to look at a Fumoto drain plug. I know others here have used one, and I've had them in the past. The question is: can I get my hand to it easily?
Johnkn
MD
it is still 15 screws ment to be for an aerodynamic. aerodynamic ? ford pickup and aerodynamic? two incompatible things.
Well, that's certainly not true., LOL ..... and not how the Auto Industry works....
Tiger Dude
Skip
Louisiana USA
2023 XL
Pretty sure nothing can get next to the drain plug without removing the "aero" cover. The Fumoto just keeps you from stripping the threads.
mavmav
Walter
New York
The way it works that Ford is drilling bunch of holes in skid plate as a "solution" for engine fire recall. should i worry about extra hole for my convenience ? I just will drill one more hole to expedite oil filter replacement. JUST ONE MORE HOLE 🕳
Ford Maverick remote oil draining.... 1670620856187
:ROFLMAO:
Johnkn
MD
:ROFLMAO:
I have no clue what you are talking about, you stated:
"it is still 15 extra screws to unscrew it. will extra hole harm aerodynamics? is the purpose of plastic cover for debris protection or for aerodynamic. aerodynamic ? ford pickup and aerodynamic? two incompatible things."
to your incorrect aero comment I responded 'that's not the way the Auto Industry works'
Aero is very much a part of the Maverick and every vehicle's designed and build...
mavmav
Walter
New York
No problem. i will explain. What i mean maverick or any other pickup of this type is not an aerodynamic car at all comparing to other cars that are like a water drop shape. An extra hole will not change car aerodynamic.
Simply put, aerodynamics is the way air interacts with objects, in this case a ford maverick will have extra hole in addition to the holes that ford dealers drill. during recall.
Therefore, I should not be concerned about extra hole. it will not effect virtually not existing drag coefficient i would assume ford mav. drag coefficient 0.4 range. i don't know actual drag efficiency of mav. but it is still a brick shape with bunch of exposed parts underneath of the car that cause huge aerodynamic drug. i still love my brick. there is nothing not to like for 22k
Sliphorn
Missouri
2022 Ford Maverick XLT Hybrid
I have an idea. Remove the 15 screws, remove the under engine guard, change your oil and filter, re-install under engine guard, wash up and go have lunch.
