Rear sensors
Eja20
Efrain
16 pilot
I’m looking at color matching my bumpers but I’ve seen you can paint the sensors and then it says you shouldn’t. I personally don’t care as to I don’t use them I tend to do old school look back and my mirrors. But on occasions that the wife takes it that’s another story she relies on those sensors and camera and even if I tell her to watch out chances are she’ll forget.
If I were to paint them I’m sure they wouldn’t work as well but will I hear a constant beep thinking I’m too close to something?
Is there any Ford vehicle that would plug in play that are already white?
lariat lux Oxford white
Old Man
Nebraska
2023 Lariat
Any time a safety system is disabled/not working I would guess the system is required to cause notifications probably annoyingly. Since there are vehicles with them in painted bumpers the question is does it require special paint or just the standard vehicle paint. Should of bought a black Maverick then paint around the existing black sensors.
1fifty
North. East.
A bunch.
Put some electrical or plastic tape on them and try it out?
The aftermarket set that I bought states in the installation instructions that they can be painted - don‘t know if OEM’s are the same.
Watchcmdr
Az
Alto blue Lariat, fx4, 4k
just curious. Did you have to remove the bumper to install your sensors?
1fifty
North. East.
A bunch.
Nope.
Drilled in the vertical section
Watchcmdr
Az
Can you provide pics on the hole locations?
1fifty
North. East.
A bunch.
Ford Maverick Rear sensors F80CEE44-6BC5-4C2E-A6A5-2014083D3270
Eja20
Efrain
16 pilot
What sensors did you use?
I’ve found part number 15k859 for the sensors. It looks like I can color match them so next I need to go under and see if all them are the same or if I need to get specific ones
1fifty
North. East.
A bunch.
Mays
Mays
WA
Mav XLT hybrid
How did you route wire to indicator / speaker in cab? Under truck, thru passage ways?
1fifty
North. East.
A bunch.
I ran them through the bed side and then into the cabin and mounted everything behind the right rear seat on the bulkhead.
