Rear locker engaged at 60mph
Tremor1942
Phil
Pennsylvania
2023 Maverick Tremor
Was driving back country paved roads at 60mph...with doggo upfront and he stepped on the locker button somehow. Didn't realize it till I saw the amber light on the dash. Should I be concerned...., probably was on for 20 mins.fwd lock was not pushed
Grand Nat.
NYC/ L.I
Schwinn Stingray
I have a Tremor also. I am not sure but I doubt if it would have made any difference being that there was no extra loads on either wheel for the computer decide whether to lock it or not. And that's if at that speed it was allowed to operate at all. Have to research that. :unsure: All I can say is it works great on the sand. 😊
710-oil-614
Cal
2025 Hybrid AWD Lariat
Nope - since the Tremor's RDU uses wet clutch packs to engage and "lock" the wheels those clutch packs also disengage rather than let it bind up and cause damage.
You should be a-okay.
Connell
Connell
PA
f150
So it sounds like a limited slip, not a true locker, correct?
Swede.
Magnus
Gritcity, PNW
-24 XLT, FX4, 4K, 'Terrain'
Also got to remember that with modern tech like this, Ford would never made it possible to even engage it is it was over a speed they deemed it not being good for. They make things 'idiot proof', especially when under warranty.
Snox801
Levi
Spring Lake Michigan
Agree, It was not engaged after 20th anyway. The f-150 disengage at 20mph for safety. This will be no different and since it’s a clutch not a true locker zero damage was done
Tremor1942
Phil
Pennsylvania
Thanks everyone. Now I just got to figure out how to cover these switches !!
OneAlienBoi
Kev
Utah
Explorer
Freaking dogs and little kids man. They definitely have their perks, but man do they drive you nuts some times 🤣. Hope everything is ok. Lots of stories on here of people's kids or dogs hitting things they shouldn't while driving.
710-oil-614
Cal
You'll need to define "true locker" - do you mean mechanical? No it is not a mechanical locker.
It is a true locker in the sense that it will lock the rear axle and both wheels will spin at the same rate regardless of traction.
It is smart enough to know when someone is about to misuse it and it prevents itself from being damaged.
Maverickman74
Shane
Maui HI
It's a high grip computer controlled variable active on the fly clutch based differential. Pushing the button tells the electric clutches to work at their best. Otherwise it is always working back there when traction becomes limited. I wouldn't leaving on all the time as use does add wear but not really more than anything else. I'm sure there is a recommendation somewhere for speed limits but I don't know it.
Howard
Howard
Indiana
24 Atlas Blue, 2015 Escape
Even if this were a true mechanical locker with no unlock mechanism, there would be little problem out on the highway with no sharp turns where differential action is needed. In town would be different.
notfast
Los Angeles CA
'26 XL hybrid AWD 4K tow
I was thinking the same. Shaft-driven vehicles always have slop in the drivetrain. Even with true part-time 4x4s, I follow the quarter-turn rule-of-thumb. That is, I wouldn't sweat driving in 4H or 4L on dry pavement so long as I don't have to turn the steering wheel more than a quarter turn.
Mikknj
Mikk
New Jersey
Maverick XLT Luxury CO360
Doggo -- I love that name!
LADemien
Lonnie
Eufaula, Alabama
2022 Ford Maverick Lariat 2.0 AWD
My pooches also like to dance on my center console buttons. Have not yet come up with a good cover for it yet.
