Rear end lowering
Zanky
Sebastian, FL
2024 Maverick XLT Hybrid
Has anyone lowered just the rear end & if so what parts?
Bobby Chapman
Bobby
Orlando fla.
2023 maverick
I would like just rear as well , the aftermarket headlights I put in do not adjust high enough, so lowing back a little would help me .
Mox4615
Jeremy
NC
2024 Lariat
I used the rear coils of an Escape. I’ve heard others used ones from the Lobo. Pics for reference
That looks comparable to what the lobo springs look like installed. I wonder if the payload capacity is any different.
Carbonized Nate
Nate
Denver
2024 Ford Maverick XLT
What headlights?
Carbonized Nate
Nate
Denver
K9-DAD
paul
california
2025 ford maverick 1966 mustang
Installed the OEM ford LOBO spring kit part number M-5300-MV $140.00
These are Only for AWD
I only installed the rear springs supplied in kit plus new hardware that is included in kit.
Back is now 33 1/4
Front is now 32 3/4
Going in for alignment today will post update of before and after
Ford Maverick Rear end lowering IMG_7260
Ford Maverick Rear end lowering IMG_7261
Mox4615
Jeremy
NC
2024 Lariat
Back is now 33 1/4
Front is now 32 3/4
Is it noticeable to you? I ordered the same kit because of how cheap it was but haven’t put it on yet. I measured the rear stock height and it’s like 34 1/8, So that measurement you took with the rear springs installed is barely even an inch different from stock, so I was curious if you actually noticed a difference.
K9-DAD
paul
california
Yes definitely it lost the rake that the truck has from factory
From my hitch to the ground it lowered 1.5 inches from before install.
Completely worth it to me.
Jus remember to remove the shock lower bolt And the lower spindle bolt
