They look like these?I bought them on Amazon but any parts store should have them
What color wires did you find were the parking lights?
Would you do it again with the same lights or go smaller?
Ordered September 28. Still no update other than first response of order.When did you order yours? We ordered 11/30/21
You could probably do that. Those connectors hold on a panel that hides my wires but that bar between the lights is a hollow tube of sorts. Might be a little more difficult that's allNice. If I were to do it, I would maybe try to go in the grill between the bars in line with the lights but looking at the picture with the grill removed, I don't think that would be possible looking at the way the connectors seem like they are spaced out.
Probably notCould this be done without removing the bumper ?
Yes, I forget the brand though. The right and left marker lights are wired independently of one another but at the connector you can see the wires easily. I think I used the green/red and black wire for the left marker light. The 3/4 lights for perfectly. A little trick is to install the grommet from the inside so you don't have to look at itThey look like these?
I absolutely hate DORD / DODO grilles lolI was expecting it to say DORD like the other knockoffs. Yours looks good. Keep it up.
Each trim has a diff grilleBased on stock photos, your grill looks different, is it? If so, where did you pick it up from?
Thanks!
It's a stock xl grilleBased on stock photos, your grill looks different, is it? If so, where did you pick it up from?
Thanks!
I wonder how 3 lights would lookI drilled into my factory XL bumper from the backside with a 3/4" hole saw in reverse for a super clean cut and wired the Raptor style lights from the amber marker lights on the bumper.
