Rain-X windshield washer fluid - yes or no?
El Kabong
El Kabong
Carnation, WA
There was a lawsuit settled in 2024 against Rain X for this exact problem. According to the lawsuit, the following products caused the level sensor to stop functioning.
The suit specifically names the following Rain-X products:
  • Rain-X All-Season Windshield Washer Fluid
  • Rain-X 2-in-1 Windshield Washer Fluid
  • Rain-X De-Icer Windshield Washer Fluid
  • Rain-X Bug Remover Windshield Washer Fluid
I use Rain-X Platinum , not mentioned in the suit.
Do you know if they reformulated product for this or what the company did to alleviate the problem?
Pointyears
Richard
South Central PA
2025 Maverick Lariat, 2018 Mustang convertible, 2012 Harley Softail, 2024 Vita
when i was a teen, i put ammonia in my mom's reservoir. it's ruined the washer pump. off to the junkyard i went to get another.
When I was a teen I waxed a windshield. Never made THAT mistake again!
Pointyears
Richard
South Central PA
I wonder what the other factor(s) is/are. There has to be something else or it would have affected everyone.
El Kabong
El Kabong
Carnation, WA
My first wife did that on an old Granada that was gifted to us. She used Simoniz paste wax. I will never forget watching the wiper blades judder across the windshield the first time I drove in the rain after that.
White vinegar and elbow grease removed it, not sure it would work on modern waxes though.
Cancunbadlands
Cancun
Cancun
Yes, it's all I ever use
Looking at the lawsuit filing it only particularly affected continuity prong level sensors that measure the presence of fluid via two electrodes and detecting if current passes between them
Ford Maverick Rain-X windshield washer fluid - yes or no? 1780272694631-ms
These are more common on European brands (BMW, Mercedes, VW) and some post-Daimler Chryslers.
Ford has typically used reed switch magnetic sensors: the float has a magnet that's held near the switch when there's fluid which causes the switch to close.
inline_five
2023 Hybrid XLT
I use the standard rain-x bottle and wipe on the protection and honestly can't remember the last time I even used my wipers.
SM2535
NH
2025 EG Hybrid Lariat AWD
Orange in the winter, Green in the summer. Been using those for the last 4 years without issue.
Hootbro
Don
Delaware
2025 Ford Maverick AWD
I avoid the Rain-X branded washer fluid stuff. Have had problems in two vehicles over the years where it either gummed up the low level sensor and/or clogged the nozzle end.
I have never seen any correlation to put my finger on why it works for some or not for others.
It really is a simple product that one just pours in a reservoir and the only statement by Rain-X about mixing with other washer fluids is that it will reduce the effectiveness of their product but no prohibition from mixing.
shadow_munk
Lobo
i used it in my ND Miata, had to replace the level sensor because it got clogged
Manning
Northwest Arkansas
2025 Lobo low
I had never heard of the potential issues. I'll have to remember this. Good to know.
Kilonen
Cedarville, MI
I think it depends on the design of sensor used in the fluid reservoir. I had a 2001 Golf GTI for 24 years. I switched to the RainX fluid when it came out. A year or two later my sensor kept telling me I was low when it was not empty. Took out the sensor - cleaned it real well - problem went away for another year then problem came back. Did some searching of forums and found that VW did not recommend using RainX fluid because it created a waxy build up on the sensor prongs. The sensor apparently used fluid to 'connect' the prongs - when the sensors got coated no 'connection' even with fluid. Cleaned the sensor - switched to non branded fluid you get anywhere and never had the problem again.
