Radio problems - frozen / freezing
newmaverick
southern california
ranger
I was using apple car play and all of a sudden it stopped working and disconnected. Then the radio screen froze and I wasn't able to use the touch screen at all, it was completely frozen. I turned off the maverick and opened the door thinking maybe it would reset but the radio stayed on even after the key was removed, door was open and then closed. I tried starting it and putting it into reverse to see if the screen changing to the backup camera would reset it but the backup camera was not working as the screen just went black. When I put it back in to gear it was back on the same radio screen and again turning off the car and opening the door and closing the door didn't do anything. I called the dealer to see if there was hard reset I could do but they said I had to bring it in as the only reset is disconnecting the battery. After about 20 minutes the radio finally turned off.
Has anyone else run into anything similar and or have suggestions on possible fixes?
jmjjr6
Fremont,iowa
2022 Ford Maverick Lariat
My 2020 Ecosport did the same, same system as the Maverick, I had to go to Ford.com and get and update. So far that fixed the problem. Hope this helps.
Red Ryder
United States (TN)
22 Maverick XLT Iconic Silver
Another reason I wish the auto industry would have standardized on a form factor and interface that would have allowed aftermarket integration. They standardized on OBD for diagnostics, so yeah, it could haver been done. Rather than get into the consumer electronics business, they could have allowed the aftermarket to thrive. A DIN-PANEL format that snaps into a common dock.
Infotainment is not their core business and it shows.
clavicus
Ford Maverick Radio problems - frozen / freezing 29D0E157-779C-4DCD-A3D7-66CF07968FFC
inthecabin
Andy
2021 Ranger Lariat FX4
Try holding the radio power button and scan forward button together for about ten seconds to reset it. My Ranger would do that until I updated the sync system. It happens when you get out and back in within a few minutes..
inthecabin
Andy
Or update with usb or over the air if Wi-Fi is available when parked. It’s in the manual.
Caper
Nova Scotia
Maverick FX4
mine has started to do this too...
STARCOMMTREY1
Trey
Boligee, AL
The fix is simple. Switch to android....
Genie77
Genie
Santa Cruz
Dodge Grand Caravan
Thank you. That worked for me
Dekay
Roger
Co.
2022 Maverick XLT
Has anyone had ford do the radio software update and did it correct the problem
Chowdayer
Vince
Los Angeles, CA
2022 Ford Maverick 2.0 XLT FX4 Lightning Blue
This worked thank you!!!
