Radio intermittently does not change stations FORD Update.
ConstantinS
Constantin Sorin
Could someone post the current software version that is causing problems?
huunvubu
coppell tx
2023 Ford Maverick Hybrid
I have:
Ford Audio Software:
Version G1.8.0.1_RC15_R21461A
Revision (G1.8.0.1_PRODUCT_GD)
My Maverick was built on 11/29, delivered on 12/13 and I last checked for updates on 12/17. At that time there were no updates available.
I will check later today and if there is an update available I will post what the update is.
huunvubu
coppell tx
Interesting. I wonder why we can’t just update it ourselves by connecting to wifi.
I will check later today to see if an update is available and if it is then I will try to install it.
Flomounier1
Los Angeles
2022 Ford Maverick Hybrid
I have:
That’s the same software version I have. I connected to wifi and checked for updates but nothing happened. It just said “Last checked for updated January 22.” Then, after I drive the car for a while and check the software version, it says last checked for updates November 11th.
Nighowl2000
Roy
Ottawa
2022 ford Maverick lariat
hmm interesting. I should check mine. Last time I checked in Dec I had G1.7.2.1_R2130a revision G1.7.2.1_product_gc)
edit: still no update.
CactusMav
Brando
Houston Tx
XLT Maverick AWD 4K
Ford has released SSM 50410, your vehicle needs to go to a ford dealer for the ACM update.
Thanks buddy this is very useful idk why I have not received one….taking this into ford for something soon and I will definitely tell them!
Jah.
Jah.
Central Florida
Has anyone had the ACM update yet? Has it solved the radio problems?
tancolbert
Tanner
2022 Maverick XL
I work at a ford dealer, this came through the Ford Oasis we use to track recalls/service updates. The ACM can only be updated through ford FDRS at the dealer not over the air updates.
Joseaoe1
Jose
Green Bay, WI
2022 Maverick XLT 2.0 4K VB, 2022 RAV4 Hybrid
Yes
Appears to be fixed. Took local Ford all day to load the update. See attached. Have scanned for stations a few dozen times without a glitch. Funny Ford must have missed this in their field and lab testing. I guess testers don’t listen to FM radio (0r satellite:)
Ford Maverick Radio intermittently does not change stations FORD Update. 6D51BACE-B218-4A14-8BF2-02E50B7D1CA4
Ford Maverick Radio intermittently does not change stations FORD Update. DE2447FD-E6E8-4CBE-90EE-BCB8D221DAE2
Jah.
Jah.
Central Florida
Yes
Thanks for the info will make appointment at dealer soon. Fortunately my radio is stuck on the station (jazz) I listen to anyhow . I am afraid to play with it because I might end up with nothing or something I couldn't stand .
MattG
Arkansas
Silverado, B2300
Dropped my XLT off today for the update..Radio hasn't worked right since day 1..freezes, won't change stations etc. I called about it as it was late in the day. Radio is fixed , but now they have a check engine light (wrench) , and they can't figure it out. Been working on it all day. My radio glitch probably turned into a month long ordeal with Ford tech support and my hybrid Maverick. Lets hope not.
