Radiator Shutters sounds
Cactusgrayinny
mark
ny
2023 Lariet Maverick, 2016 CX5 Mazda
I have been trying to assign a cause to certain noises (low and unobtrusive as they may be) which I hear under the hood. I hear them when first entering vehicle even before starting. I will hear these same sounds while sitting in vehicle after shutting down. The other day I came up with a theory about the Radiator Shutters. If this is the answer, then the shutters are open or shut not variable. Any other observations on this ?
Aherpa
Iowa
Edge, Maverick Lariat Hybrid
I have been told that the clickety-click sounds are relays. I've never bothered to find out.
It sure sounds like a lot of them though.
MavChris
Macomb Michigan
23 Maverick XLT, 22 Bronco Sport, 19 Flex SEL
I hear the same sound. I have had my Maverick for over a year now and believe you are correct (radiator shudders). Hear it every morning when I get in to go to work. Totally normal as far as I know.
The shutters do a sweep self-test as part of startup. Their operation is monitored by the PCM and will set a CEL if they aren't moving as commanded.
Montana
Ford Maverick Radiator Shutters sounds EFpSTO
sorry, had to do it.
The sounds are relays though. It's the vehicles AI telling you that you are about to be skynetted.
Cactusgrayinny
mark
ny
As I said this happens before startup. What is CEL ?
BeardedK
Kevin
22 Maverick XLT
As already stated, they're relays. They do it even after shutdown at random times. It's part of the system.
Ford Motor Company
Official Ford Account
Dearborn, mi
Hi there! Would you send us a private message with your VIN and dealership name and location? I’d like to look into this concern on my end.  
Ozarkbeard
May not be true, but it seems like if I do a double-lock with the fob, the clickety clack noises happen a lot less frequently.
I despise locking the truck in my own damned garage, though.
Cactusgrayinny
mark
ny
Well, you didn't describe what the nature of these sounds are other than they're "low and unobtrusive".
Yes, thank you, it is low volume and pitch. I would not say it was "clickity-clack" , more like something opening and closing. This morning for example, I heard it almost simultaneously when the driver's door opened up on a 15 degree morning. I do not remember if this same thing happens when passenger door is opened.
