Radiator fan replacement
lvgnak
Gene
Las Vegas, NV
2022 Ford Maverick, 2.0T, 4wd
I have a 2022 Maverick 2.0, awd, off road package
Radiator fan motor went out, replaced. Keeps blowing 60amp fuses.
overheats & no a/c. This is no good in Las Vegas.
any suggestions, thanks
matmondro
Mathieu
Vassar, MI
When the fuse keeps blowing, does the fan start working again with a new fuse or does it totally fry the fan motor too?
lvgnak
Gene
Las Vegas, NV
Fan motor is ok, just keeps blowing fuse
right now it’s so hot in Vegas, it happens all the time
matmondro
Mathieu
Vassar, MI
I'd also inspect the wiring going to it just to make sure there's no chafing or shorting of other wires that may run alongside it.
It blowing the fuse is not normal, even in the hot weather. There has to be something interfering with the circuitry, or with the fan/motor itself like @CNJFF mentioned.
BlueSpec1
Gene
Fan connector contacts or wiring damaged near the fan connector?
Next I'd wonder if fan relay contacts passing 12V OK.
Cancunbadlands
Cancun
Cancun
Try to connecting directly to the battery to see if it works
