Question about 12V bed power
Hillbilly
E. TN.
22 XL
How long after you turn ignition off does the bed power stay active? Installed bed outlets and lighting.
BeardedK
Kevin
22 Maverick XLT
I’ve not timed it, but I believe it’s about 15 minutes.
Hillbilly
Hillbilly
E. TN.
22 XL
Yeah, I was installing bed lighting LED strips and it stayed active till I finished
Ford Maverick Question about 12V bed power 20230122_114951
StillWaiting
Brandyn
St pete
2009 Dodge Challenger SRT8
Mine stayed active while installing led lights then turned off. I was confused and pulled the fuse and rewired the lights. Then found that they do indeed shutoff around 15-20 minutes
STARCOMMTREY1
Trey
Boligee, AL
MJL
TN
Ram Rebel, Maverick Lariat hybrid
I haven't had mine but a few days does the interior front 12v outlet time out and shut off as well or does it stay hot
Hillbilly
Hillbilly
E. TN.
22 XL
Timed mine today. I wasn't real attentive but it was between an hour and a hour n half. That was the front also. Nothing in the manual.
dcs12345
TX
07 Chevy
pointing at bed light switch beside usb n 12V power. Front DRL's
do you happen to have links to the al the parts you used for the bed LEDs and the USB/12V power ?
PCK
Phil
VW R32; Maverick Tremor
I believe that the On time can be changed in Forscan. Check other threads to confirm.
desmobob
Upstate NY
2022 XLT EcoBoost tow package, 1995 Ducati 900SS SP, 2025 CF Moto CF500
I'm thinking of using this auto-off-after-x-minutes feature to wire a lit switch to my DIY bedight project.
If I wire the switch illumination to that same Ford-provided power lead in the bed as I'll wire the bed lights to, the switch will be lit up for x number of minutes when I exit the truck to drop the tailgate, right? But it won't stay illuminated (or draw power) after x minutes after turning off the truck.
Is this an OK assumption?
V-blue Mav
Missouri
2014 jeep Cherokee and 2006 F-150 2022 Maverick EB
FWIW. So I just installed my USB, power point, volt meter and switch yesterday. I have an XL. After the install I thought I would test the 15-20 minute on time. I fould that mine goes off when the key is turned off. I also wired it to turn bed lighting on and off with that switch once I get them. The other 3 items are wired to come on, when power is applied when the truck is on.
Ford Maverick Question about 12V bed power IMG_20230128_080630
Telemachus
Jason
XL EB (sold), XLT Hybrid
What good is accessory power of the key has to be in the truck?
I wish it were wired that it would stay on for x minutes after unlocking the truck
livinloa
Les Scott
Bellingham, Washington
www.leszbees.com
Do you remember the fuse number? Thanks!
