Deleted member 42620
Guest
I just changed the PTU oil at 1800 miles. I know a lot of people reported that it was under filled but mine was perfect from factory: about 13 ounces drained and the same amounted added. The fluid was cloudy but I didn't see any particles like others have. The magnet on the drain plug had the same "sludge" as others. Very simple maintenance. It took about 45 minutes if you include getting it on stands. (The sludge from the magnet is what is on the shop rag.)
Ford Maverick PTU OIL CHANGED IMG_6207
Ford Maverick PTU OIL CHANGED IMG_6204
Ford Maverick PTU OIL CHANGED IMG_6205
Ford Maverick PTU OIL CHANGED IMG_6206
mkebikecop
ed
Middleburg, FL
2024 Volvo S-60 recharge, cloud white, 2025 Maverick Lariat, hybrid space white
What is a PTU or RDU?
Marty
2026 Ford Maverick Tremor
Power Transfer unit and Rear drive unit.
Some young whippersnapper had to change it from PTO to PTU just so it would be new to other younguns.
Guest
In general terms, the PTU is the power transfer unit. On an all wheel drive vehicle, it transfers power to the rear wheels when needed. The RDU is the rear drive unit. It basically runs the rear wheels. Both units have separate fluids. The manual says under normal driving, these fluids don’t have to be replaced as part of normal maintenance. But it is so simple to replace them that many people add it to the normal maintenance schedule.
mkebikecop
ed
Middleburg, FL
Thanks so just to be sure we are talking about a 4wd transfer case & a rear differential
73ofalltrades
2024 Maverick
It Is Labor Day and I just changed my PTU again at 31,000 I changed it 15,000 it was under filled. I also changed my rear differential unit for the first time and it was underfilled as well. This was on a 2024.
jonshep
SW Oklahoma
I will never change that oil. My Mav is front wheel drive only. 😀😀😀
Finnster
N. E. Wisconsin
Were they low enough that you wish you had done both jobs much earlier?
I'm planning on doing my PTU for the first time at 2K.
thev8man
Booyah 👊🏽 😁 👍🏽 🇺🇸
Doesn't look so hot
