Passenger Compartment Fuses
AbnRgr
Athens, AL
Porsche 944NA, Mazda Miata, PT Cruiser Conv.
Is there a listing for the passenger compartment fuse box which identifies which are accessory fuses and which are constant power sources?
TomMav
Minnesota 55060
02 Mazda Miata
The Owners Manual. Online version is very useful.
AbnRgr
AbnRgr
Athens, AL
Thank you, but no. Is there a way to differentiate between those that are constant power sources from those that are accessory fuses, requiring a turn of the ignition key?
Easiest way for me, get one of these, clip to ground, touch the metal seen at the top of each fuse with the ignition off, and with accessories on. You’ll find exactly which ones are which.
https://www.harborfreight.com/612v-circuit-tester-with-5-ft-lead-63603.html
Someone did this over a year ago and said fuse 3 and 6. I didn't bother to test myself and used fuse 3 for my 12v switched remote power wire for my amplifier.
Mabcim
Rochester, NY
While 3 & 6 are ignition based, they are different. At least with my Eco AWD Lux. When I remote start, 3 has power but not 6. 6 doesn’t get power until I get in and press the Start ignition button.
6 is more idea for what I’m working on, but a fuse tap does not fit in there.
Telemachus
Jason
XL EB (sold), XLT Hybrid
6 is more idea for what I’m working on, but a fuse tap does fit in there.
This guy has some snapshots of someone who was able to get a fuse tap to fit into 6.
I haven't been so lucky yet, but it gives me hope...
https://www.mavericktruckclub.com/f...power-spoiler-its-all-good.10366/#post-564577
clavicus
Here’s an easier markup. Ive highlighted the ignition-only fuses. The rest are constant.
Note 1-2 and those below them are Micro3 fuses. I use 1-2 as my ignition only for my dashcam /autodimming mirror. It’s unused by the system and a micro3 fuse tap is basically as cheap as the micro2 taps.
Ford Maverick Passenger Compartment Fuses IMG_3669
Telemachus
Jason
Montana
I used 4 and 20 for parking mode on a Viofo a139. 4 for constant and 20 for ACC
AbnRgr
AbnRgr
Athens, AL
Thank you. That is exactly what I was seeking.
Telemachus
Jason
Now we need to map out which ones are powered with remote start and which ones are only powered with the car actually on.
From what I've heard, 6 is not started by a remote start.
Lpdcop
Elyria, Ohio
2024 Ford Maverick XL
Is this what you’re looking for?
I know fuse #3 is only hot when key is on. Trying to power Dash Cam without hard wireing. Are any of the two cigarette lighters or USB PORTS cold when key is off?
Hot Runr Guy
West Chicago, IL
On my '24 Lariat EB, the dash lighter port will eventually turn off.
HRG
