Oil catch can (whats everybody using?)
Barracuda340
Abilene Tx
  • Thread starter
  • Banned
  • #1
Oil catch can, what's everybody using?
Thanks
Mavonorder
Pete
Camry
Thanks
What's with the oil catch can? I've been fussing about the carbon buildup issue with direct fuel injection and came across folks discussing "catch cans" as if it could help to prevent carbon buildup on valve stems, etc. Or am I misunderstanding the purpose of oil catch cans altogether? If oil catch cans don't help with carbon buildup, etc., Is there any thing else that can prevent carbon issues with dfi engines other than buying a vehicle that uses mpfi? Thanks!
Decayed
yes
a car
They are supposed to reduce fluids getting into the intercooler. Fuel and oil blow past the piston rings and get into the crank case then go back through the PCV into the intake manifold If I understand the issue correctly. From there it gunks up everything in the turbo and intercooler where it can pool. The catch can bleeds off some of the fluids and collects them for disposal.
kcamp317
Cincinnati, OH
'20 Ford Escape Titanium Hybrid 16 Ford Escape SE
I got one of Burchers catch cans in the box waiting along along with a bunch of other parts and mods for whenever my order comes in. Its a very nicely constructed unit. Nice welds and a great finish.
Platinum2
MI
Ford
You all need to use the search feature. The topic of catch cans has been discussed ad nauseum. 🙄
Barracuda340
Barracuda340
Abilene Tx
  • Thread starter
  • Banned
  • #6
I used search feature, and like what cubanredneck did with 2 catch cans. One for upper PCV and one for lower PCV setup.
Gpp
Gil
Sanford nc
2022 ford maverick
And if it was needed why wouldnt ford put a catch can system on there at the factory 🧐
Barracuda340
Barracuda340
Abilene Tx
  • Thread starter
  • Banned
  • #8
Because they want you to bring it in with encrusted intaie valves needing a top end redo just out of warranty.
RedRider
Kitchener, Ontario, Canada
There is already a factory catch-can. An aftermarket one will do virtually nothing. The aftermarket ones are for different engines that have high blow-by when driving at the redline constantly, and are useless for most people.
todd92
None, because it's not needed.
Tiger Dude
Skip
Louisiana USA
2023 XL
There is going to be virtually zero difference in any of them. Note that almost none of them are easily removeable since you have to make you own connections, they don't give you the Ford connectors for your PCV line.
Also don't expect them to be designed by automotive engineers, all are basically made by Some Dude who drew it up on a napkin.
Barracuda340
Barracuda340
Abilene Tx
I do not run the snot out of my truck, and I empty both of em every 2K. I get lighter colored crap with water in it from the upper crankcase vent, and darker crap with water in it from the lower crankcase vent. Without them, this crap will eventually put a coating on the inside of the intercooler dropping its efficiency and will coke up the intake valves. They work.
