Oil catch can installed
catrikejoe
joe ramirez
MO
2025 maverick XL
It is supposed to help with carbon buildup on intake valves.
Separates oil and air from the mist coming from pcv . Oil drains into can and cleaner air to intake track to burn.
The new Echoboost has eight injectors to eliminate carbon build up. When or if we see carbon build up there's a recommended service procedure decarbon that's usually takes thirty minutes.
Misterwakko
Wrench
Connecticut
2022 Maverick FX4
The recommended procedure is removing the intake and walnut blasting the back of the valves.
That's not quick, easy or cheap.
CajunMick
Heman
Houston, Texas
2023 XLT Maverick
Working on offshore oil/gas production platforms, some had turbine powered pumps, compressors, used walnut shell to clean blades of salt air buildups. Spin starter, get blades rolling and throw the shells inside intakes. And do distilled water spray in the inlet. A monthly service..
