Looks like it would let water in to land on the door seal. Looks like it could increase cabin noise.
What reason would you need to vent that location ?
If just for looks I get it, looks cool as ell.
I opted for theseThis is available from Ford Accessories fyi. Here are some before and after pics:
And totally unnecessary. The thermostat will compensate and maintain the same engine temp.Those vents should be able to lower your under-hood temps a bit! Looks nice!
Good points. Although the turbo & its associated parts are nearest to the vents. A cooler turbo is a happier turbo?And totally unnecessary. The thermostat will compensate and maintain the same engine temp.
During a hard winter the thermostat may have to close even more. That level of ventilation could cause a hot spot In the motor during the dead of winter.
Just speculation. It’s how my brain works.
So you’re saying I should abandon my quest for putting heat extraction vents in the hood also?And totally unnecessary. The thermostat will compensate and maintain the same engine temp.
If by "bit" you mean 0.001 °F, then yes.Those vents should be able to lower your under-hood temps a bit! Looks nice!
Are you experiencing overheating issues? Is that why you want to vent under hood air?I live in the desert where rain is sparse - but dust is plentiful.
The path to the engine is open however. I’m hoping air will flow out of the vent not in. That is its purpose - let hot air escape from engine bay…
Going to let the 3M tape cure for a day before driving. The quieting foam over the tires is still in place. My worst fear is that it whistles or something! If so, the included covering goes under the mesh.
The purpose of heat extraction vents are to minimize heat soak. OP states he lives in the desert too.And totally unnecessary. The thermostat will compensate and maintain the same engine temp.
Not totally cosmetic. Under hood temps will be lowered by a few degrees. Something like a 20 or 30 F difference would be a stretch, but could it be 5 F or so? Absolutely.If by "bit" you mean 0.001 °F, then yes.
This is a cosmetic mod.
There are plenty of ways for under-hood heat to escape and prevent heat soak; for example, along the entire length of the hood where it meets the fenders. I doubt very seriously that the small amount of added ventilation is going to make a difference in the temperature of a water-cooled turbocharger. If heat extraction from this area was that important, people with upper trims of the Maverick would be removing the insulation where the fender and door meet.Good points. Although the turbo & its associated parts are nearest to the vents. A cooler turbo is a happier turbo?
