No Engine Brake on COLD ENGINE
The Real Maverick
Jack
  • Thread starter
  • Banned
  • #1
I noticed a weird startling effect today.
No Engine Brake on a COLD ENGINE!
2022 Hybrid
Parked at the top of an 1800' hill.
Left on a COLD ENGINE with mostly full battery. And by cold, 45-50°F.
15% 18% 22% peak downgrades. Pavement / Blacktop Residential.
Numerous hairpin turns and narrow road only 1.5 lane wide mostly. 25 mph was uncomfortably fast.
3-4 miles of continuous downslope.
Have a ScanGauge.
Left on EV after key turn.
Got from parking lot to steep downgrade in 0.1 mile.
Regen started right away.
HV Battery hit 70%+ in 0.1 mile.
Cold engine did the initial start ON GASOLINE. HV battery hit 72% and stopped taking any more regen.
Engine continues to run on gas AT IDLE (1250 RPM) to warm up engine and catalyst. 150-250 MPG indicated. Not zero. NO ENGINE BRAKE AND NO REGEN GOING STEEPLY DOWNHILL ON A COLD ENGINE.
After about 2 minutes, 1 mile or so, engine and catalyst warmed, fuel cut off (999 MPG indicated) and RPM climbed to 3500-3600 to provide engine pumping braking, as is typical.
I had to ride the brake pads pretty hard that first mile on 18% to 22% downgrade in narrow winding residential, but at least it was only 1 mile.
I probably did 1000x normal daily wear on my brake pads this day.
P.S. the L button did not help during this 2 minute warm-up period.
Master Blaster
Master
Toronto
23 Maverick Lariat Hybrid
Interesting that the engine jake braking was insufficient for your situation. How did anybody allow a residential neighbourhood to actually be built with an incredibly dangerous 22% grade? The DOT design limit for a maintainable road is 7%. If the battery became fully charged and the backup jake braking was insufficient then I'd be pretty worried that you're reaching the limits of tire adhesion on that kind of angle. I daily do a mile on a 7% grade and have never even reached the point where the battery recharging limit was reached and so never had to go to jake braking.
Tim d
Alpena
Ram
2022 Hybrid
Have a ScanGauge.
This reminded me of an algebra problem....quit reading about halfway thru.
Moorparkmark
Moorpark CA
2024 XL Hybrid
A 22% grade = a 22 foot drop in elevation per 100 feet of travel.
Headbanger
Ron
Finleyville PA
2023 Maverick Hybrid Lariat
I live in Pittsburgh and these streets are no joke.
Marty
2026 Ford Maverick Tremor
Well I’m glad you didn’t kill yourself OP
