New Gorilla Maverick Lugs do not work
Lynyrd Skynyrd
22 Maverick
Edit- these do not work! Gorilla was mistaken :mad:
These finally came in and do not work. They thread up fine, just do not seat well.
Original post below
Talked to Gorilla directly and they have a M14x1.5 nut that’s 1.4” long, will not stick out like others.
They told me the only direct authorized retailers are SFX performance and Summit racing. Taking a chance on eBay and Amazon with clones
Ford Maverick New Gorilla Maverick Lugs do not work 3C86B83E-D99A-4EF3-B42D-9A170EA38E87
Ford Maverick New Gorilla Maverick Lugs do not work 8D0B4BFF-9655-4F83-92EB-66DD3BEEAAC4
Ford Maverick New Gorilla Maverick Lugs do not work 08734D9A-D4D4-492E-AFB9-B27FA894FC83
I
Ford Maverick New Gorilla Maverick Lugs do not work 3ED3FBFF-EB3D-4573-8A2C-45E3E85E0DD1
Lynyrd Skynyrd
Lynyrd Skynyrd
22 Maverick
So found out these don’t work as gorilla told me they would.
can anyone answer the big mystery what a name brand solid lug should be?
I’ve had issue with all ford lugs with the cover. Wtf is that about. Anyway it’s a lug nut, should not be that difficult
Ranch
Sacramento CA
2023 Marverick FX4 4K
I don't know why those don't seat well. I have a different brand on my Amazon wish list for when my Maverick comes in but they are also 60 degree lug nuts.
NoVaJimmy
KCMO
Lexus GX 460
Interesting. You sure you have the correct product? I'm using gorilla lugs with my BS sport wheels with no issues. They seat perfectly
Lynyrd Skynyrd
Lynyrd Skynyrd
22 Maverick
They seam to bottom out without even tightening. I slightly tightened and it left a groove half way up the taper part the rim. Will they hold the wheel on? Probably but long term unsafe imho as they do not seat all the way
For now I’ll keep the ford lugs and a any size fits all lug remover incase the outter shell crush’s (it’s what crooks take your locks right off, quick, easy and sold about anywhere)
Ford Maverick New Gorilla Maverick Lugs do not work 5D63B9BA-9D99-4146-A607-563E0161CDCD
Ford Maverick New Gorilla Maverick Lugs do not work DF1F1AFE-3470-4465-A369-66F11AF18305
Lynyrd Skynyrd
Lynyrd Skynyrd
22 Maverick
I forgot. Gorillla guy told me this is a new lug for mavericks that they discovered it works. Probably not all rims is my guess. What part# did you use?
NoVaJimmy
KCMO
Lexus GX 460
71643NBC
Lou'sBluMav
Lou
Upstate SC
2004 Chevy Colorado(sold Oct) 2018 Subaru Forester
You're making me nervous, as #91743 is exactly what I ordered from Summit Racing (with a precise referral from the Gorilla expert) in mid-Sept (when I had a Sept 29 build day). MY '23 build day is Jan 13 so I won't be able to see if they work until Feb.
I understand the problem is they are not deep enough to seat properly. I plan to use them with a XLT Hybrid with stock Al rims. Is that what you tried, and have you contacted or gotten a response from Gorilla?
Hot Runr Guy
West Chicago, IL
You guys realize that BS wheels are sized for 12mm studs, not 14mm like Mav uses. If the holes were 2mm larger, the tapered area would be also.
HRG
JamesC
LI, NY
06 Mustang GT
I have XLT wheels ready to put on when I finally get my XL hybrid. I‘ll hold off on buying black lugs for now just in case there‘s an issue and I need to return them.
NoVaJimmy
KCMO
Lexus GX 460
HRG
This has been discussed ad nauseum here and there is no issue, there is plenty of seating area with aftermarket lugs like the Gorillas which are made to fit a wide variety of wheel types with a 60 degree seat.
