Escape lugs/locks fit the Maverick or not?? Please help ASAP
klutch14u
MO
2025 Maverick XL
I bought a stock set of 19" wheels and tires off an Escape that I'm putting on my '24 XL. I got the lugs and locks that went with the wheels. I'm trying to find out for sure if these lugs that came with the Escape wheels will fit properly on the Maverick. They need to be balanced, so I'm going to the auto shop by my house and letting them put them on after balancing out. I just want to avoid surprises with the lugs and searching had mixed results.
BradnChristine
Brad
Wyoming
Easy. Take one of your Maverick lugnuts off and compare it to the Escape lugnuts. Try it on for size on the Maverick. M14 x 1.5 lugnuts are on many Fords.
EONR24
Swag
United States
2024 Ford Maverick XL
Personally I do NOT like OEM Ford Lug nuts. The lugs are not well made and have a cap on top of them that eventually will become damaged from taking them off with an impact. Look into getting some gorilla lugs! They are much better made than OEM and they make them in oem sizes and smaller.
jsus
2022 Ford Escape Hybrid AWD
No, you cannot use Escape lug nuts on a Maverick. Escape uses M12 x 1.5. Maverick is M14 x 1.5. Because Truck. You'll need to use your existing Maverick lug nuts or source more in that size.
