Or just see post 21 here.Paste "Ford Racing Intercooler" in a search window and you will find a $150 FMC discount coupon that reduces the Mishimoto price to $850.00. Accrue points???
That is what happens when you start a post, stop to eat ribs while watching the Bears/Rams playoff game, finish your beer, THEN hit the "Post Reply" button. I got intercepted!Or just see post 21 here.![]()
Is every intercooler like that? You need to cut the radiator fins?Hey Carlitos_92 I said that because unless you cut the active grill shutters off, you can’t remove the intercooler without removing the AC condenser. Everything thing is stacked on top of each other and everything sits inside the radiator core support.
After installing the CV fab intercooler I changed the radiator out for a towing radiator. It was a complete pain in the a$$, without discharging the AC.
It isn't radiator fins - it's the active plastic shutters that control how much air gets into that lower grille opening.Is every intercooler like that? You need to cut the radiator fins?
Loud and Proud! Not for everyone, but definitely my style.![]()
This is what I did for the CV Fab intercooler install![]()
Ford just released an intercooler for 22-25 EB Mavericks. The price is steep at $1K
https://performanceparts.ford.com/part/M-6K775-MAVU
When are you going to make one for the larger 2.5 L engine?
just joking here... LOL
All Ecoboosts (if not all turbo engines at this point) have intercoolers; this is just a larger one for performance applications.I kind of feel like this should be standard but not a surprise it is not.
So a more robust intercooler can actually make the turbo HOTTER (by increasing the engine’s output) and require more frequent oil changes..,All Ecoboosts (if not all turbo engines at this point) have intercoolers; this is just a larger one for performance applications.
In any case, this cools the pressurized intake air. Oil cooling is handled elswhere.
Nope. Not only is the intercooler AFTER the turbo, the intercooler by itself is not going to "increase the engine's output."So a more robust intercooler can actually make the turbo HOTTER (by increasing the engine’s output) and require more frequent oil changes..,
If cooler intake air will not increase the engine output (hp) - why would you install a more robust intercooler in the first place?Nope. Not only is the intercooler AFTER the turbo, the intercooler by itself is not going to "increase the engine's output."
