My truck bed aux power has no current / voltage
Mymaverick2021
Steveo
Hilo Hi
My Meverick ecoboost 2.0 has no voltages or current from truck bed auxiliary power access points, Any thoughts?
Once again people Asking warranty questions here rather than going to their dealers where they're supposed to take their truck
LGA737
New Jersey
Maverick Lariat, Tesla Model 3, Tesla Model Y
Did you measure the voltage with a load plugged in? Many inverters won’t invert until they sense a load connected. Try just plugging something in and see if it works.
Andy
vinnie
vincent
Livonia,Michigan
2022 maverick
my problem is i have some power but not enough to run anything
vinnie
vincent
Livonia,Michigan
2022 maverick
this happened Saturday so couldn't call dealer so i was hoping to maybe get some help. i am going to call dealer first thing in the morning.
vinnie
vincent
Livonia,Michigan
2022 maverick
Ok fond out about the reason why i can't use my saw with the plug in the bed of the truck, it is 900 watts and the plug only can be used with 400 watts so good luck finding a use for it. I am pissed about it.
Captain Pork chop
Andy
2010 Chevy Silverado
Buy a 2000w inverter and hook it up too your battery
PaidEMS
Pennsylvania
2005 Saab 9-3
I appreciate it, will call a dealer on monday.
Did you find a solution to your problem? I am having the same problem.
Edit: Found the solution. Fuse is #88 (20A). It is not labeled on the manual. There are also fuses on #87 (40 A) and #90 (60 A).
Goosey
Chicago
2016 Mustang
Thank you for this. Didn’t have power back there and it was fuse 88 that’s blown.
wax87
Stuart
Dallas South
2004 Avalon
well it is really the amperage; 110 V at 300 watts = 3.3 amps, you say 400 Watts, I guess it is different for the bed and the cab inverters?
Jcar
Jack
Minnesota
2024 Maverick Lariat, 2010 Escape
I have a 24 Lariat Hybrid with push button start and discovered that the Start button needs to be pushed a second time for the 110 outlets to be live. The engine DOES NOT have to be running
BlueOval1954
The Maverock doc indicates the outlet in the truck bed is 400W so you shouldn't be upset. Whoops, I was responding to a very old post.....sorry.
Robot-Wrangler
Kentucky
I have a '25 hybrid with no 115VAC. I've called a dealer twice getting only voice mail, so I guess I'll get a meter and start checking fuses under the hood. My home is under construction and I would like to use the Maverick for a tool battery charger and an LED light bulb. Of course the truck shuts down after 30 minutes, lol. It's 100'+ to the temporary power.
