MikeyG
phila
Started to working on my stereo system and thought I would share the process here and also get some advice along the way. I’m no stereo expert and have only done one system probably 12 years ago that was in my previous truck. I have never hooked up amps to a factory radio so I’m still trying to figure out what route I’m going to go with but I’m looking for something not expensive and user friendly so I’m thinking lc7i. The amps I’m using are alpine mrp300 (4 channel) alpine mrp500 (mono amp) and a 10” sundown sd2 that I took out of my old f150. This is just a basic build that I’m not looking to spend a lot of money on it. I bought lower end morel 6.5” components and 4” rear speakers. I also have some 0 gauge power wire that I took out of my f150 that I might use.
here’s the sub, components, rear speakers and power wire.
Ford Maverick My stereo upgrade process in Maverick XL 14DD3A8D-0B62-4999-8223-7005574EACAE
Ford Maverick My stereo upgrade process in Maverick XL 0BEF7763-7F9C-4514-8906-CE534DFBFBDB
Ford Maverick My stereo upgrade process in Maverick XL 6FA6ACDB-887F-4D3C-B3F4-FABDE3536225
Ford Maverick My stereo upgrade process in Maverick XL 740E8729-D5B3-4901-B57C-305B000320D5
Ford Maverick My stereo upgrade process in Maverick XL 8D597A11-ABAF-4A0A-A20C-4E5AF373E2C3
getting an idea for the amp rack. This is just a scrap piece of mdf I had laying around so once I figure how I’m going to do the rack I’ll get a new piece of mdf.
Ford Maverick My stereo upgrade process in Maverick XL FA9642C2-4193-4C82-A514-173DF074B935
Ford Maverick My stereo upgrade process in Maverick XL 9AC941D9-5654-43CB-8BD9-2D5C687975A3
MikeyG
phila
ordered a loopback harness from plug and play kits. This will tap into the speakers for me and bring the signal back to my amps.
Ford Maverick My stereo upgrade process in Maverick XL 76EFA193-23AF-41A3-A905-33C6A11FB320
Sound deadened the bins under the rear seats.
Ford Maverick My stereo upgrade process in Maverick XL 59B7AB62-9BB7-41E6-86A5-13B0982E98C2
MikeyG
phila
now for the box. This is my first box that I ever built. My 10” sundown called for .5 cu ft so in order to get the right volume I had to use 1/2” mdf.
Ford Maverick My stereo upgrade process in Maverick XL 7A6C3A3D-AD8E-4E56-B849-FA15C62D0261
Ford Maverick My stereo upgrade process in Maverick XL C0D9B7FE-EDD7-4DB8-83BD-0CDF60B087B8
Ford Maverick My stereo upgrade process in Maverick XL CC1CC315-E2AF-4901-84AC-22D8B4D2A718
Ford Maverick My stereo upgrade process in Maverick XL D1108445-6DCD-4341-BD6A-D9DA5F01589B
Ford Maverick My stereo upgrade process in Maverick XL 9C050C47-99F6-4B65-943A-E6DDA990834D
Ford Maverick My stereo upgrade process in Maverick XL CC09869C-30CE-41A6-9C21-52D6559B3CC0
had to cut out all the sides and the bottom of the plastic bin in Oder for the box to fit.
Ford Maverick My stereo upgrade process in Maverick XL 594B64CA-E21A-4857-9F4A-3CFA72916B3B
Now for the top trim piece to finish everything off. This is all 1/2” mdf
Ford Maverick My stereo upgrade process in Maverick XL 80614B42-AB71-478C-BBA5-4A507732C479
Ford Maverick My stereo upgrade process in Maverick XL 0EE34C60-5261-432E-B2AE-29412D471DC8
last the holes cut and cover piece covered in leather
Ford Maverick My stereo upgrade process in Maverick XL 5F98C282-A8DD-4A38-AFA2-1DCC468963AB
Ford Maverick My stereo upgrade process in Maverick XL 8E3F8856-2898-46FB-9F26-91C3383BF811
Ford Maverick My stereo upgrade process in Maverick XL 31DA0AC4-7249-43D5-83A7-64B5167DB06B
Ford Maverick My stereo upgrade process in Maverick XL B86D27DA-E1D4-4C0E-89CE-55375346DFE2
Ford Maverick My stereo upgrade process in Maverick XL FA6FED7D-FC37-4E4E-8D98-C64665D481F8
Ford Maverick My stereo upgrade process in Maverick XL B7ECCD82-219A-4937-9D52-5739C26C1CA4
Ford Maverick My stereo upgrade process in Maverick XL ABD6D9EC-AB35-427A-83BD-F67AB9D66BF5
Ford Maverick My stereo upgrade process in Maverick XL BCE230FC-D8D7-42E5-A425-93D1F14764C6
Ford Maverick My stereo upgrade process in Maverick XL 13E69CDB-A538-4AB6-B34F-950A7A9725D2
Ford Maverick My stereo upgrade process in Maverick XL 13F3E1C0-2D2F-4AF3-ADC3-1CEF647833E0
Ford Maverick My stereo upgrade process in Maverick XL 9A93C0B6-FF0A-4BA8-B47D-B1007186B560
You're off to a pretty good start. What did you cover the box with? That looks pretty nice and it's fairly close to the factory blue plastic color. (y)
MikeyG
phila
Thank you! Here’s the link to Amazon where I got the faux leather
Osunnus Faux Leather Upholstery Fabric by The Yard 55" Wide PU Faux Leather Sheets for DIY Crafts Christmas Home Decor Furniture Cover Car Marine Upholstery, Navy Blue https://a.co/d/14zslkZ
rclee
Rob
Dayton Ohio
That is a great job! You are quite the craftsman.
rallyshark
Donny
GA
2023 Maverick Hybrid
Great work! That sub looks like it belongs there, and great choice on the mids/highs too! Can you tell us more about that harness you got, and where you got it from specifically? So it carries the signal to the amps, but I'm assuming you will have to run the speaker wires back to the front from the amp for the fronts, right? Where are you going to connect the amplified channels to for the fronts at? Don't get me wrong, I know how to make it all work, I'm just curious about how much trouble that harness is saving, and if it would be worth it for me to do. Currently, I plan to run a 9 conductor speed wire, and simply snip the front speaker wires at the harness and take it from there.
I bet it will sound so much better than stock now! I will say, a DSP before those amps will open up a whole new world to you though ;) Once you go DSP, you never go back, haha. Having full control over the sound profile is awesome(a must even), and you can really dial it in to it's full potential. Either way, really nice work man!!
WNYEscapee
TJ
BFLO
2023 Maverick, 2019 Cherokee
Nice looking box. The vinyl was an excellent touch. How's the overall improvement in sound quality?
I haven't done anything audio related in probably almost 25 years, though adding some bass to this audio system would be a big plus -- it's definitely lacking a bit there. However, the factory audio isn't as bad as I was expecting, but still nowhere new the bass of my previous Ram.
