Maverick Lobo - Fake Engine Noise?
Mabcim
Rochester, NY
Found it! In the ACM (As Built) I changed 727-01-01 xxxx-xxxx-1xxx to xxxx-xxxx-0xxx and that disabled the engine sound enhancement.
Thanks great news.
I found a F150 thread about it for those, but the position for it didn’t make sense when I compared it to mine and a Lobo.
I just found a newer F150 spreadsheet and that seems to match what you found.
I pulled up a Lobo VIN, believe it is 401a not 701a, and it has a 0 in the position. The VIN I looked up was 3FTCW8TA2SRA48214. And it has:
727-01-01382B14F20099
This is what my Lariat has:
727-01-01301730F6009D
710-oil-614
Cal
2025 Hybrid AWD Lariat
I can understand putting fake noise in an electric car but not a gas burner.
I mean if you want fake noise why not make it sound like a top fuel dragster or an F ONE or Indy car.
That would blow someone's mind at a stop light
BTW is it possible to upload a video here?
Why would you put fake noise into a vehicle that doesn't produce any (beyond the safety sirens) and the owners don't pine for 70s displacement nostalgia?
Buggy Man
Summerfield Fl
2025 Maverick Lobo, Meyers Manx clone dune buggy
Could you feature a TESLA that sounds like a HARLEY?..........NO !
rk06382
Robert
Alaska
2025 Velocity Blue Maverick Lariat Hybrid, 1990 Ford Ranger XLT SuperCab
Fcnrwy
Jerry
Wisconsin
Maverick XL Area 51
I have a "lowly" XL and can "hear" the Four-Banger sound, (which sounds like a Rally Car) when I wind him up.
For those who don' t like the "piped-in" sound (I can NOT find any samples on YouTube), why not change the Sound file....
To something to your liking.... :ROFLMAO:
Jerry
OleFordGuy
Cougar70
Glen Burnie MD
2024 Maverick XLT Hybrid
alex lobos
Alejandro
Chicago Illinois
2025 maverick LOBO
Thanks great news.
This kinda confused me. So I know I specifically looked for the lobo 701a package when I bought mine. Would it still be the same value? Justin stalled a amp high inputs because idatalink doesn’t work with the 2025s so the engine noise is amplified 😣
Mabcim
Rochester, NY
The noise stuff should be in the same position on all Mavericks, whether it is set or not. So if what I found was the correct position, it isn’t set on my Lariat and not set on that 401a Lobo. So either it isn’t the correct position, or just a 701a Lobo has it turned on.
I do recall another forum member posting saying they turned it off for their Lobo. I don’t recall for sure what setting they used.
alex lobos
Alejandro
Chicago Illinois
2025 maverick LOBO
Ok that clears it up a bit. I have the 701a. It might have to do with all 701s have the B&O standard? I’ll definitely mess with it after work and a beer today. I thank you much
Buggy Man
Summerfield Fl
I have the "standard - base" model LOBO. In the window sticker it says: EQUIPMENT GROUG 402A.
What is this 401A and 701A? Maybe the color difference???
alex lobos
Alejandro
Chicago Illinois
2025 maverick LOBO
402 and 702 is basically the standard lobo (402a) as the 702a is the premium lobo. The 42-44k one with 99% of every available option. Most dealers only get 402a and very very few will order a 702a package. As that was the specific trim I was looking for. Well at least by me. 1-2 lobo 702s within 100 miles miles of me when I was looking.
colinl
Colin
ICT
it's 402A and 702A, but either way it's extremely easy to tell which lobo you have.
if you have a 6x9 sub behind the rear seat backrest you have B&O audio which in a 2025 means you have a lariat, lobo 702a, or tremor. there are many other differences also such as 360 cameras.
if you don't have a 6x9 sub behind the seat or 360 cameras then you have a Lobo 402A.
btw for trucks with aftermarket amps this doesn't really fix the system chimes like seatbelt nag, door ajar, etc. if you don't come out of the sync4 unit with a2b, those are going to be amplified. you can do the audio cheap or you can do it right, lol.
Mabcim
Rochester, NY
Sorry for causing confusion, they end in “2”, not “1”, like others said. They have also explained the differences, so I won’t repeat.
