- First Name
- Mike
- Jan 1, 2026
- Northwest Arkansas
- 2025 Lobo low
- Engine
- 2.0L EcoBoost
Did another event over the weekend.
First run was fine, everything worked as expected. Then on the second run, turning off stabilty was a little odd. By the second or third corner, I could definitely tell stability was still on as it won't allow full throttle with much steering angle. I thought oh well, that was just learning the course.
But before the third run, there were multiple error messages on the dash about "hill hold not available", "pre collision braking not available" "advancetrak not available", etc. No amount of turning it off and back on again did anything. But it seemed to drive fine, so what the heck, let's finish out the day. The last run was a few tenths quicker than run 1, so apparently, I was able to drive around the issue to some degree.
Conditions........It was in the low 90's, very sunny, and only a light breeze. So fairly hot. I had all 4 windows down all day. I worked the first group, so the truck sat with the hood up all morning, and the engine/trans was nearly ambient when the second run group was called up.
So did a bunch of socializing afterwards, packed up and left. About 1 mile from the event the messages stopped. I tried the drive modes and they worked, and was able to turn off stability.
Afterwards I put all this info into google AI and it came up with two or three possibilities.
1. Camera in the windshield over heated.
2. The Image Processing Module A either overheated, or
3. became overwhelmed from the course. Apparently the IPMA can be confused and overwhelmed by lots of stripes and objects the camera sees, and has to decide whether or not they are hazards.
If I was to bet, I'd bet on #1. It was hot and the issue resolved itself quickly with driving with the AC on. Maybe it was #2 for the same reasons. I don't think it was #3 since this was the 7th event this year.
Picked up a Dragy Pro to play with. It showed consistent 0.89-0.90 g's lateral (0.91 peak) and braking, and 0.58 acceleration. The night before the Lobo demonstrated multiple 6.4x second 0-60mph times, with a best of 6.41.
On a different note, that was the last autocross with the OEM tires. Pilot Sport 4's are going on tomorrow. Sunday's event will be fun!
