Maverick Inner Door Sill Protector Demand
Toddman45
St. Louis, MO
I just added it to the Black Friday discount, and the discount may take about 10 minutes to take effect. If it takes effect, I will notify you immediately. ;)
Thank you, Ordered!
Maxzina
Maxzina
Diamond Sponsor
New Jersey
Here’s the thing. You guys are like a much worse version of Mabett. The trash can lid excuse for a hood scoop was the main event that put it all on display.
Howwever, the real kicker is that you never acknowledged that miss and almost doubled down on your product offering since.
I’ll just say it - these look like shit. They don’t match the existing trim, they don’t even compliment it with color or pattern, it’s like you’re trying to not to match for the sake of being contrarian.
You guys might be the worst vendor on MTC not named Fast Mavericks.
You are right.Decorating the hood is our failure. The original intention of our development was to reduce resistance, but the fact has not had any effect. We have communicated with multiple Mav owners in the FB group, and this product will be taken down in the future.
This is truly a rather failed work.šŸ˜”šŸ˜”šŸ˜”
Scupking
2025 Ford Maverick XLT Hybrid
This is great! I think I will order some when I get my 25.
zach57x
FL
2022 Maverick XLT
More vendors is what drives after market support. And just because they make something doesn’t mean you have to buy it. Plenty of use-less & stupid mods from every vendor on this forum imo.
I purchased the mud flaps from maxzina. Mabetts were known to fuck up the paint. Maxzina no issue at all and fitment is perfect and it looks OEM. Definitely not a much worse version…
Hot Runr Guy
West Chicago, IL
I was looking to protect the areas where I end up dragging my size 14's or hitting the toe. Especially if I am unable to fully open the door. In a parking lot for example. Yes I even covered the weather stripping.
Great idea on using PFF to cover the weatherstripping, I find myself peeling it back from time to time.
HRG
VrtualOtis
Derek
Seattle, WA
2024 XLT Hybrid - Cactus Gray
Is there an ETA on when these will be available?
Tim d
Alpena
Ram
After listening to the opinions of the owners of the Mav, a inner door sill protector for the Mav has been designed. The image is for reference only. This is a sample created, and since there is no identical material, other patterns were used to make the sample first. The products sent to Amazon later will be made of the same material as our outer door sill protector. Our inner door sill protector comes in a 6-piece set. Perhaps everyone has this requirement?
You can decide whether to use the mats circled in red. Mainly the 4-piece set of inner door sill protector, with the other 2 pieces as gifts.
Two thoughts, the fact this product has to be made attest to the quality of the interior plastics, second thought, apparently people are this picky? A cpl scratches doesn't bother me.
MightyMaverick
Connor
South Florida
2024 Ford Maverick Lariat FX4
I'll have to get one once it's available. I like the inner one because it prevents anything from falling underneath the seat such as loose change out of my pocket. Also, since I'm obsessive, it'll keep any dirt contained in that mat instead of on the carpet. It's tricky trying to vacuum in between the door sill and seat trim because of how narrow it is. It'll be one less area to clean which I'll appreciate.
bobbyd454
bob
usa
2025 ford maverick
You can now purchase.It has 20% discount now.
If
I don't see the reason for it. They don't look good, are of little use, and if you cannot lift your feet over that part of the door opening, you should drive a camry.
Chilipepper
Pete
Louisiana
Lincoln was
You nailed it! Faulty useless add on’s
710-oil-614
Cal
2025 Hybrid AWD Lariat
Did you codevelop the hood scoop?
JTBII
Indiana
2024 Ford Maverick XLT
Great idea, can’t wait until they come out.
Tremor1
Ron
Maverick Tremor Lariat, Ram 1500, Audi RS4 Quattro
Thank you for the many add-on's that have been great from Maxzina and for admitting when there is a fail. I can't wait to get the interior door sills they are needed. I wish you would consider my other two suggestions the lower door kick and the door pillar where the seatbelt retracts. These 2 areas especially the lower door kick scratch if you look at them the wrong way. I can't get protective film to stick, yes I am picky and it would be a nice add-on. Thank you again for bringing these products to market.
Jakedangler
Jake
Farmingdale nj
2024 ford maverick lariat
Can I get the link for this I’m unable to find on Amazon
Maxzina
Maxzina
Diamond Sponsor
New Jersey
šŸ¤” Just interesting
I was glad you developed something for the inner sill.
I like the blue color of my trim, therefore, I used clear PPF to cover the inner sill and lower kick panel of the door. Not having access to a cutting plotter any longer I have cut everything by hand.
I put these on šŸ‘† in August as a test. Of produce and placement.
.šŸ‘‡
So far the actual painted door sill that I covered with rubber grip tape doesn't get much scuffing.
Good idea!
