Maverick 2022 Steering Wheel got crazy
sprcoop
AZ
2023 XL Hybrid, 66 Mustang Coupe, 2012 Focus DCT
My wife's 2012 Focus had a similar issue with the electric steering. It forced you to make many direction corrections while driving straight down the road. There was a recall and hers got the steering components replaced.
Fady
New jersey
Ford maverick 2022
Much thanks for explaining
Fady
New jersey
Ford maverick 2022
Maverick 2022 Steering Wheel got crazy while i try parking at work,
the steering wheel bounces back and force , the computer screen restarted
check this video. @Ford Motor Company
This ehat the dealer said
we had to reprogram your PCM, and took it for a long test drive and everything is working as it should.
BradMav
Brad
2024 Ford Maverick
Sounds like an insufficient explanation for an intermittent and dangerous problem. Were they able to *consistently* reproduce the problem before the reprogram? If not, how do they know it’s actually solved just because it didn’t happen during one test drive?
What was wrong with the program, are other customers at risk of the same problem with the program? Programs don’t just change… they even have checksums on their code so even if something did change on its own due to a failure of the storage media(bitrot), the checksums would not match and not allow the faulty code to run.
They should provide a sufficient root cause to such a dangerous issue.
Fady
New jersey
Ford maverick 2022
i agree i attached the response from the dealer mechanic
Ford Maverick Maverick 2022 Steering Wheel got crazy mav
Fady
New jersey
Ford maverick 2022
the below is mechanic report
CAUSE:
12651D BODY / CHASSIS / ELECTRICAL (BCE) TEST 5658 WP94
12651D45 BODY/CHASSIS/ELECTRICAL
POINT TEST - L
5658 WP94
FC: H50 04
PART#: 3C529
24283 Unable to verify the customer's concern. Scanned for codes found code in ps pscm u3000, checked the power and grounds for the pscm okay. Checked oasis for TSBS and SSMS and found SSM SSM 51812 2020?2022 Escape/Corsair, 2021?2022 Bronco Sport, 2022 Maverick ? Lack Of Power Steering Assist At Engine Start-Up With U3000 DTCs Stored In The PSCM reprogrammed PSCM and cleared all codes, road tested vehicle and verified repair.
Fady
New jersey
Ford maverick 2022
what do you think?
Fady
New jersey
Ford maverick 2022
he does not rotate it 360. it appears to bounce back hard when he hits the end of the steering travel in either direction.
there have been some trucks with issues with the electric power steering. I am not sure of the systems, what is involved in repair, etc. I just know I've read of a similar issue before.
what do you think?
Fady
New jersey
Ford maverick 2022
Not sure home much torque is on that wheel jerking back but If you were a woman with narrow wrists that would be an injury right there blamed on Ford and Mav production would halt lol.
what do you think?
Fady
New jersey
Ford maverick 2022
NOT ANOTHER POTENTIAL RECALL TO DELAY MY DELIVERY! 😭
This looks pretty bad, I've seen similar/worse things, and usually it comes down to the steering wheel control module. Be safe out there, glad they are offering tow and loaner
what do you think?
dags1207
Dallas, TX
2023 Ford Bronco | 2024 Ford Maverick
what do you think?
Maybe the the PSCM reprogramming solved it. At least there were able to find codes to have some history/data behind it.
Keep all paperwork just in case :)
Fady
New jersey
Ford maverick 2022
So it Happened again in less than a month this time it happened on the road the steering wheel stuck after drove out of the driveway, car at the dealership for 3 days with no answer
