Mabett side marker lights turn signals
inline_five
2023 Hybrid XLT
I saw the Mabetts. Thought they looked cheap and the wrong color. Did these myself. twelve bucks, look great when on, right color and blacked out when not on.
That looks great
Mdmac
Kansas
2023 Maverick XLT
Where did you get the lights? Are they easy to wire up and are they also blinkers? Thanks
JPinPA
Jay
Stewartstown PA
2024 Maverick XLT
Hello, I have purchased a set and after 2 weeks the passenger side is full of condensation. It is a problem as others on the Forum have mentioned. Hope you have better luck. Tried to contact Mabett but had to leave a voicemail
In addition to the passenger side issue on two sets now, the driver’s side now has condensation!
Ford Maverick Mabett side marker lights turn signals IMG_3118
What a pita.
At least Mabett's horrible quality is consistent on both sides.
Some members think for $90 that it is a great deal. Expecting to take apart properly seal and make it what should be coming directly from the manufacturer.
Mabett should advised in their ad.
Required,
"Disassembly, proper sealing and reassembly before installation, for proper waterproofing."
jcnnjc
Newnan Ga
Fiesta ST , Alto Blue Maverick awd fx4
Has anyone disassembled and sealed them up yet? Mine have condensation in them, love how they look and work, but they won’t last long getting wet.
Ford Maverick Mabett side marker lights turn signals IMG_5283
Yes they have.
There is more then 1 thread on this subject.
You just have to look through the postings.
Sorry, I can not help any further.
Since Mabett is having manufacturing problems properly sealing these. I decided not to purchase.
Mabett could drop 👇the price.
Sell it as a "Kit' some assembly required.
Good luck
GB
Toddman45
St. Louis, MO
For the true DIY crowd and those who like an OEM look, I attached detailed guidance based on my custom side marker and turn indicator installation. 3 images included.
Exact same thing I plan to do after I ptm them. Same leds as well, found em on SBL.com for 3.99 a piece locally.
Palms
Gus
Jensen Beach, FL
21 Mercedes GLC; 23 Maverick Hybrid Lariat
Follow the directions provided and you'll have them on when your low beams are on and they'll flash with the turn signals. I did the driver's side first and tested it, then I did the same wires on the passenger side and tested it. No issues since I installed them a couple of months ago.
I just got my lights and the instructions provided only cover the driver's side. I watched a YouTube and wired the passenger side accordingly but the passenger light is always on, as others have reported. The problem is seemingly with the passenger side red wire connection. Ideas or suggestions? Thank you,.
Maverick2023
Kip
Atlanta, GA
Toyota Rav4
I connected my red wire to the passenger side marker bulb so that it would stay on whenever the parking light or lower beam light is on. Access to the side marker bulb on the passenger side is much easier than the driver side.
Palms
Gus
Jensen Beach, FL
Does your driver side red connect according to the instructions and behave how your passenger side does after connecting that one to side marker light?
Deweyordeweynot
Dewey
Macomb, MI
On the passenger side, I connected the red wire from the kit to the solid blue wire on the headlight connector. The yellow wire went to the blue and white wire on the turn signal connector. I had no issues with it so far on my 2024 XLT.
Ford Maverick Mabett side marker lights turn signals 17217470598417685640746472890696
Ford Maverick Mabett side marker lights turn signals 17217471782716367811764817328352
Palms
Gus
Jensen Beach, FL
Thank you sir! I will check my wiring on the passenger side to see if I have a solid blue, create a connection for it and see if this will solve my issue like it did for you. Out of curiosity, how did you determine this wire as mine came with instructions that ended in step 18, which is the completion of the driver's side installation but no mention whatsoever about the passenger side. I used the wire indicated in Fred's Garage (?) YouTube video but that definitely doesn't work. Thanks again!
Deweyordeweynot
Dewey
Macomb, MI
I looked at which wire I used for the left side and noted its' position in the connector, then used the wire in the same position on the right side. I also decided to use the t-taps that came with the kit, though some on here don't like them. I did tape them for a water-resistant seal and it's been nearly a half year and 8k miles with no issues.
Palms
Gus
Jensen Beach, FL
That is the best advice as apparently the wire colors change depending on the Maverick model. For my 2023 Lariat Hybrid, the passenger lamp wire is the blue one as correctly indicated by another contributor. This should be pinned as advise as there have been so many installations and probably more to come: for the driver side, use instructions, no problem. For passenger side use same wire locations, regardless of color. Excellent!!
Deweyordeweynot
Dewey
Macomb, MI
Glad to hear it worked out. Enjoy!
