- First Name
- Mike
- May 3, 2024
- KC Metro area
- 2005 Toyota RAV4, 2024 XLT Hybrid
- Engine
- 2.5L Hybrid
So that's likely standard SOC% chart hopefully AGM value (sadly there seems to be different versions), which means the voltage is easily 11.95 to 12.15, with 30% being 11.8 (where mine lives).For sure. I lock it religiously when not driving and it routinely sits at least over night locked, if not for a few days (since I work from home).
The battery typically lives between 40-60% regardless of my driving habits. However, it bottomed out in the 30s regularly during the DSM moments. I recently had it checked, like mentioned, and when it came back from the dealer, it was 95% (I assume while they were doing over night testing), down to 75% by the time they returned the vehicle, and back to living in the 50s within 2 more days.
The numbers are reported in percent, though, so I can't see the voltages unless I'm in the vehicle with a voltage meter plugged into the cigarette lighter. It's at 15v while running and dips into the 12s when not, typically around 12.5 that I've seen, but I hadn't sat there and stared before.
Unless you mean you have a scanner on OBD port, and reading from there.
Morning voltage read is useful - 12.5 is great. Doesn't match standard or Ford SOC% scale though.
Since it's not dropping from the 50s, sounds like just an age problem, can't hold a charge.
In their test, held good enough though to not fail, and for hybrid, good enough for a start.
Just not good enough for modem to be left on.
Also cold - doesn't charge high when cold battery. So winter is bad.
Do you use the AC, or maybe humid enough it's turning on anyway without the lighted button? (being in WI, wouldn't think much, not during winter).
Because ACCM module was one true intermittent parasitic draw they determined was worst, and have a software update for it.
