low 12 volt battery voltage while driving
whitlightning
mark
wyoming
2026 mavrick
I have a 2026 hybrid mavrick 17k miles 3 months old i installed an obd II gauge cluster
I was cruising at 67 mph and noticed my 12 volt battery voltage droping it got as low as 12.1 volts never got back above 12.6 volts until I turned off the car and restarted it
anyone out there got any ideas
El Kabong
Carnation, WA
Well, the 12v power in the hybrid comes from a DC to DC converter (no alternator on the hybrid).
So we would need to know where the OBD gauge cluster is getting it's reading from. If it's reading the 12v output on the CANbus connector it's getting it from the DC converter instead of reading a PID from the control unit.
What gauge is it, do you have a link to it?
Where do you recall it starting from that you saw it drop to 12.1?
Close or over 14V?
The charging strategy for yours is float charge Amp current from 87-92% SOC, Volts would display upper 13.x but probably more like mid 14.x.
At 92% SOC, the 12V battery takes the 12V system load, and drops back to 87%, to repeat.
Volts would be reading 12.8 down to whatever during that time.
If you drive long enough it starts charging back up again.
Forget the volt reading when you are done driving - that's a bogus useless figure for 2-4 hrs after a battery has been charged.
True voltage is going to be less than that reading - you just don't know by how much.
You turned it on - if quick enough it picked up where it left off, discharging, just happened to read higher.
Wait long enough like 1-2 hrs before starting again, it likely would have started the charging up again.
whitlightning
mark
wyoming
2026 mavrick
it is reading the pid I have had it in the car for nearly 12000 miles and this is the first time I have seen this happen
whitlightning
mark
wyoming
2026 mavrick
Close or over 14V?
car normally runs between 13.8 and 14.8 volts I have had the gauge installed for roughly 12k miles and in that time only saw this happen once a few days ago
Well congrats - you got up to the max possible with default strategy.
Kind of. But it's good news for the next bit, battery isn't so low this won't work.
Next time you see that change from abouts 14 V to 12.x V, do one of the following:
Turn on your parking lights, or head lights, or fan speed to 6 or above.
Wipers turns on your headlights too eventually if needed.
Read all about it in first few posts here. He's updated those to keep current.
https://www.mavericktruckclub.com/forum/threads/hybrid-12v-battery-mystery-solved.81553/
Hopefully you do enough longer drives for this to be useful.
If not - use a battery charger to get it up there - then be watchful and do it.
Cherokee
Marty
2026 Ford Maverick Tremor
The Maverick Hybrid,
The Ultimate piddle with machine.
I opened my Tremors hood and checked the oil then added some washer fluid today.
:’P
whitlightning
mark
wyoming
2026 mavrick
thank you for the info have a great day
Mavster Mechanic
Hybrid
You're not supposed to add washer fluid to the oil unless you are at -40 degrees or colder. Thins it out too much in warm weather.
