Locked out for the second time.
Bobkath
Prescott, AZ
BMW Z4 roadster ,Highlander 24 pepper red hybrid
Locked the doors and when I returned from the store, the key fob did nothing. Acted as if it needed new battery. The last time this happened I used the key to open the door and it activated the alarm but still unlocked the door. This time, I used the Ford app and that worked fine. Too bad Ford eliminated the keypad,
Has anyone else had this problem? 2024 XLT hybrid. 4000 miles?
KevCuRaoi
Kevin
Buffalo, NY
2025 Maverick Hybrid XLT AWD
Is only one key acting like that? If so, try changing battery in fob?
Chilipepper
Pete
Louisiana
Lincoln was
You should be able to purchase a keypad for it at the dealership.
Bobkath
Prescott, AZ
If you do that, how is the key pad attached to the truck?
I checked into that and the keypad is stuck on the truck with some adhesive, and battery operated. Not cost effective in my opinion. Not sure of any color options for it and the one I saw was white.
HoiToid
Not yet, but I drove 50 miles this morning mostly at 50-60 mph; after I parked & locked it, I used key fob to unlock it twice to get some tools out~~~ suddenly got the dreaded " deep sleep, you need to drive your truck to recharge battery" message.
How many miles do ya have to drive to keep this from happening so quickly?
Mavis Blue
Elaine
South Carolina
24 XLT
That happened to me once so far. My husband used his fob, and it worked. Tried mine again, worked fine. I have also had the truck lock with the keys in it several times. Luckily, the back doors don't lock! Glitches?
Bobkath
Prescott, AZ
Haven't received the deep sleep notice and hope not to. Mine seems to run on electric often. Even short trips have had no issues of deep sleep.
BlueMav43
Roger
NE FLA
2023 Ridgeline RTLE, 2018 Tahoe LS
Thank you. Think I’ll pass. The one on my Bronco Sport was “built in”.
Chilipepper
Pete
Louisiana
Lincoln was
It’s a regular Ford part that they have sold for several years. I had one added to my F150 years ago with no issues. It is attached with a special 3M adhesive tape. Comes in handy
TedTX
Ted
San Antonio TX
Could also be the way Maverick shows an aggressive breakin was attempted. My Silverado did something similar when I did a overnight in a older area in a tourist town.
Watch when you get out of the truck and be sure you are not accidently pushing the manual "lock this door" lever above the lever you pull to open the door. This has been reported in the past as being done.
Decayed
yes
a car
It's a shame ford did away with the hard wired version - That thing has saved my bacon a couple of times. but at least the battery powered one works.
