Lighter Weight Tires
DangerZone
Arizona
XLT hybrid Maverick
While unsprung mass definitely does have an effect, you will likely never make up the cost of new wheels with improved gas mileage (even with $5+/gallon).
Oh, thank you.
So conversely if I get wheels that are heavier than stock it won't hurt gas mileage very much.
Maverickman74
Shane
Maui HI
I always look for hevier tires for puncture resistance, but if its light you want, you should probably look into carbon fiber or racing type rims and low profile tires. Maybe a lowering kit too.
ShadowBlack XL440
Robert
Northern Ohio
I'm looking tires for my hybrid Mav that are lighter in weight than the included tires but still have the capability of those tires. My understanding is that the included tires are about 25 pounds. Has anyone come across tires that would meet these conditions?
I went with this package which was about the lightest setup I could find. 18.4# per wheel and 23# per tire.
Ford Maverick Lighter Weight Tires 1656803839009
Ford Maverick Lighter Weight Tires 1656804011972
Ford Maverick Lighter Weight Tires 1656804056160
Flomounier1
Los Angeles
2022 Ford Maverick Hybrid
Weight reduction will only make a noticeable difference in MPG if you get rid of at least 500lbs of weight probably.
Edge Haley
Edge
CARBONDALE-Atlanta
PORSCHE
Would take a lot of searching to find them, but a number of people on this thread have installed wider and heavier and had drastic MPG loss. One on here (XL) reported loosing 6 and 7 mpg with wider, heavier tires...he went back to his original wheels and tires that he had for sale and regained his MPG.
Maui
Cape Cod
'23 Kia Soul Convertble
Fill them with Helium!
stoptothink
Utah
'17 VW jetta
Oh, thank you.
"Very much" is subjective. Obviously, lighter is better, but the difference is likely negligible. While there are many factors, general estimates suggest for every pound dropped per wheel, efficiency can increase up to 1% - up to a point. The more miles you do in stop and go, the greater the improvement (the improvement will be less if you do a lot of highway miles). If you want wheels, get wheels, but don't rationalize it by saying it will save you money - again, you'll never make up the cost you've spent over just keeping the stocks on.
raymaines
Ray
Tacoma, Washington
Alto Blue Lariat Lux Hybrid
Any thoughts on brands of aftermarket wheels. I've noticed a number of people using Motegi brand wheels.
I wouldn't even try to match the colors. I'd go with chrome, silver, gray, or black wheels.
DangerZone
Arizona
XLT hybrid Maverick
Have you seen any smoothie type wheels that would fit the Maverick?
raymaines
Ray
Tacoma, Washington
jonnyredbeard
Jon
NY
All I know is the stock tires on the Lariat are terrible. I got stuck on wet grass two weeks after I bought it. I have 13k on them now and they will need to be replaced at 20k. Thats ok but as someone else pointed out they must have been going for MPG or something becuase the performance even on Dry pavement isn't great.
Guv
Ford
I've been looking into lighter rims myself to replace the steelies. I've gone down 5lbs per wheel before and it made a huge difference in braking and acceleration from a roll (same wheel dimensions).
The C-Max has some nice light wt. wheels, not sure about the bolt pattern.
catinthebathtub
haas
houston
66 GT 350, 60 VW, 34 pickup and porsches....
Thank you, lighter rims it is then. My Mav is oxford white what do you think of white rims?
i chose rims for mine sorting by lightest weight first (and then by $$) and found these 18" konig freeforms to be just over 18#. the tire i selected is wider than stock (and 29#) but i am still indicating 30.5 MPG daily commuting my turbo. 7K miles and only left the city limits once.
Ford Maverick Lighter Weight Tires A51
