Just because, not for a specific actual use, if I had an XL (assuming all drive trains are electrically identical). Or perhaps find a hybrid maverick that has severe hail damage, I would consider seeing other options.I mentioned heat in a earlier post. It is getting up towards the limit but hasn’t hit it yet. There’s decent amount of heat in the compartment already from the exhaust under the truck. Using bigger cells and a beefier BMS could offset that heat due to them taking longer to warm up and generating less heat during high current charge and discharge due to less resistance. Another option is to use some insulation on the metal body to prevent that heat from getting to the battery. Then I removed the trim piece, it opened up a little bit of a gap between the bottom of the seat cushion and body and that probably helps too.
If what you’re thinking with the power walls is to turn the maverick into a whole home generator like the F150 power boost does, I don’t think that’s possible. It just doesn’t supply enough current for that in my testing.
Also 12v basically has a soft limit of around 2400-3600 watts of power due to how high the current would need to be to get there.
