- First Name
- Leo
- Nov 7, 2021
- Geismar Louisiana
- 2022 Lariat FX4 Maverick
- Engine
- 2.0L EcoBoost
Do you mean they fit or that they fully function in the turn/stop socket (i.e. no hyperblinking)?I agree. The backup lights are bad. I just ordered the WT21W bulbs from Amazon, will install Saturday.
Update: WT21W leds easily fit in the middle (backup taillight) socket. They do NOT throw codes and do not need resistors. (For grins I also tried them in the upper and lower stop/turn signal sockets and they worked perfectly there as well)
Tried here. They work for turn signal but do not do both the tail light and brake light. So at night the tail lights will not be on unless you brakeDo you mean they fit or that they fully function in the turn/stop socket (i.e. no hyperblinking)?
update, the wt21w/7w led bulb works for both tail light (lower light emitted) and brake light/turn signal (highest light emitted)... the lights do not hyperflash but the turn signal sound/display goes at twice the speed in the cabTried here. They work for turn signal but do not do both the tail light and brake light. So at night the tail lights will not be on unless you brake
have another bulb coming in Monday I’ll test
adding resistors will fix the hyperblinkWell darn. The freaking loud-ass blinker sound already drives me nuts. I wonder if a set of resisters would help.
Appreciate the update!
How do add resistors?adding resistors will fix the hyperblink
You can either by some that splice into the turn signal wires or you can add in-line ones which go between the bulb and the factory wiring. That’s the easier optionHow do add resistors?
Thanks for the info.I ordered these on amazon and instslled them a week ago. Zero issues... No resistor necessary.
Did you do white for reverse and red for tail/turn/brake?I ordered these on amazon and instslled them a week ago. Zero issues... No resistor necessary.
Haven't done brake yet..Did you do white for reverse and red for tail/turn/brake?
You won’t need resistors for reverse bulbs… brake/turn you willThanks for the info.
