Keypad not functioning
cremarkk
2024 Maverick
  • Thread starter
  • Banned
  • #1
The number pad on my wife’s 2023 Maverick has worked flawlessly since day one. All of a sudden, it still locks the doors but won’t unlock them.
cremarkk
2024 Maverick
  • Thread starter
  • Banned
  • #2
Any suggestions? I’ve really gotten used to this feature.
The number buttons are confirmed working - or it wouldn't work one way.
The wiring is confirmed working - or it wouldn't work one way.
Seems like a logic problem on the internal chip or the truck.
Do you hear the locks like being engaged when they should be unlocking, like when you hit the remote lock button when already locked?
Or silence?
cremarkk
2024 Maverick
  • Thread starter
  • Banned
  • #4
Or silence?
When I try to unlock using the keypad, there’s no sound at all, no click, no motor noise, nothing. It’s just silence, like the signal isn’t being processed at all. Definitely feels more electronic than mechanical.
Welcome to The forum 🤝
Seeing is how you're starting out with a problem. I hope we can help.
Does the keypad illuminate when you push any of the buttons?
Things that don't make sense. You confirmed that pushing the bottom two 8/9 buttons will lock the truck. That means that the keypad is working.
Ford Maverick Keypad not functioning 20250605_103616
Some things that I've confirmed.
When pushing a button, the keypad should illuminate but there is no sound all.
Is there any hesitation??
You have Less Than 6 sec. To input numbers.
Once the light goes out on the keypad or 5 1/2 seconds transpires, you have to start all over again.
DaVicar
Hendersonville NC
2023 Subaru Crosstrek Limited, 2023 Maverick Lariat hybrid, Alto Blue, BAP
I would try reprogramming the code:
Ford Maverick Keypad not functioning Capture1
Well, doesn't seem a logic problem then, of it thinking the locks are in the wrong state, and just redoing the same request, in this case another lock.
I assumed the wired and wireless keypads merely sent a command to change state of locks, something fobs don't have.
And it was up to truck system to change the state from what it thought it was.
"have you turned it off and back on again?"
Since a big computer - Forscan Lite has service procedure for rebooting modules.
If you don't have an OBD dongle and Forscan Lite - your closest ability would be disconnect negative battery terminal and wait 5 min.
I was going to ask if this had been resolved but it seems this member is no longer on the forum.
