Keyless touch entry question
Stimpy433
Chad
Iowa
2022 Mavrick
Is it only on the drivers side front door, or does it work on the passenger side front door???
Clarkdonbran
Only driver’s.
The Weatherman
Dean
KY
Both front doors have the lock sensor on the handles. I’m 99 % on that, but I’ll run out and check. If I’m wrong I’ll let you know.
TSAINTS1115
They keypad accessory or the ability to unlock more than the drivers door when the code is entered?
In settings it can be set to unlock the drivers door only or all.
Stimpy433
Chad
Iowa
2022 Mavrick
Not the keypad, I’m talking about when you touch the actual door handle.
Stimpy433
Chad
Iowa
2022 Mavrick
I swear I’ve unlocked the passenger side door with the handle, but the last couple of times I’ve tried it, it hasn’t worked.
Naranjita
NAH-RON-EE-TAH
Steamboat Island, Washington
In Lariat/First Edition touch sensor works on both the driver side and passenger side door handle so long as the keyless FOB is within proximity to the radio sensor. But not the rear doors. The Ford Keyless numeric keypad is driver side only.
Stimpy433
Chad
Iowa
2022 Mavrick
Well, I went out and tried it again, and I’ll be both sides lock/unlock by touch!!! Don’t know why it didn’t work the other day, must be gremlins….
Kingmyster
Randy
Utah
2022 Ford Maverick Lariat VB Lux w/ FX4, Tow, 360
mine only works on the driver side
SaintClairMaverick
Novi
Saint Clair Shores MI USA
My driver side actually stopped working but passengers side still works. I have to take it up to dealership anyway for recall so I'll have check it out.
Stimpy433
Chad
Iowa
2022 Mavrick
Mine‘s been working great, not sure why it didn’t work that day…. Make sure you give it a second or two to unlock before you pull on the handle.
06Warrior
Person
19' HD Road Glide, 22’ Sporster S
On my Mustang the passenger side touch unlock won’t work if it hasn’t been used for a certain amount of time or if the car hasn’t been driven or started etc for a certain amount of time.
jsus
2022 Ford Escape Hybrid AWD
My Focus would sometimes act up where only one of the front doors would unlock when I grabbed the handle. Only ever did it in winter, so I presume there was some sort of snow/ice blocking the sensors.
TimmH
Southwest Florida
2018 Jeep Wrangler
In vehicles I've had that had keyless entry, I've noticed the FOB position is critical. Sometimes simply turning the pocket with the FOB away from the vehicle was enough to put it out of range.
My wife's Challenger is the same way.
Nighowl2000
Roy
Ottawa
2022 ford Maverick lariat
Had same issue.... It was also dead of winter when I had issues.
