Key fob...poor design?
Offroadx
Renegade65
23 maverick lariet and 24 envista
One of few peeves I have about my maverick.....is with the new key keyless start fob...........it seems if I do anything besides hold it my hand the panic alarm often triggers...
Put in coat or pants pocket barely bumping anything seems to set it off. Its rather annoying and embarrassing as then have to dig out keys to turn dang thing off........shouldn't panic button been more recessed?
rk06382
Robert
Alaska
2025 Velocity Blue Maverick Lariat Hybrid, 1990 Ford Ranger XLT SuperCab
I purchased this Leather Car Key Fob Protector with Zipper
to stop beeping horn! o_O
Ford Maverick Key fob...poor design? 71NxdVFQd9L._AC_SL1500_
Old Young Man
Patrick
Ormond Beach
2024 Maverick Lariat Tremor
My slip in cover helped, but still have problems occasionally. What good is a fob you never have to dig out if you have to reset the alarm ? Toying with the idea to disable it.
Chilipepper
Pete
Louisiana
Lincoln was
Apparently you have a defective one. My wife and I carry ours everywhere every day in my pocket on key rings and in her purse never had an issue.
DontFret
DontFret
Ontario, Canada
2025 Maverick XLT
Maybe you could try a fob cover? I use one and haven't had any accidental button presses. Amazon has several styles to choose from.
I agree as well. Faraday pouch keeps the fob safe in a robust case and from being accessed remotely by would be thieves. And have not had any accidental issues with the fob being triggered. FYI
DontFret
DontFret
Ontario, Canada
2025 Maverick XLT
FYI…See attached.
Ford Maverick Key fob...poor design? IMG_0399
Waterick
Laurens county SC
I have Faraday pouches too, but I really hate making the already too large fob even bigger.
dhaskit
Dann
2024 Maverick FX4 Lariat
Offroadx,
I don’t have time to find it for you but if you review all of these videos of Oscar Leroy, I’m sure he has a solution for the same peeve that you have.
It’s very important to post things of critical importance like this for all to know just what keeps you up at night.
Master Blaster
Master
Toronto
23 Maverick Lariat Hybrid
FYI…See attached.
I had that exact pouch from Canadian Tire, and it was pathetic. Try closing it and then trying to use the door unlock and you'll notice that there is still sufficient signal leaking from the pouch that it is failing to do its job. Now I use a small tin and it works far better.
DontFret
DontFret
Ontario, Canada
2025 Maverick XLT
I would respectfully disagree. When I have the fob in the pouch in the truck I get a message that no fob is detected. When I approach my truck with the fob in the case, the doors will not unlock. I’m not sure what brand is at CDN Tire. FYI
MikeS1942
Windsor Ontario
24 Maverick Lariat
Wrong--this is a fairly common issue. Accidentally put it in your back pocket and sit in a soft chair. I've set mine off numerous times. Put it in my front pocket and bend over, will set it off as well. I've had many key fobs, but none as sensitive as these.
1929
Lake Michigan
Ford Maverick XLT Hybrid
No FOB issues with XLT, no keyless.
