Is this bed cover installed correctly?
DanaL
Dana
Rhode Island
2024 Lariat
This is a factory installed hard roll-up bed cover.
I expect it would seal, but I get rain and snow in the bed.
Does anyone else have this cover, and does this look right or wrong to you?
Ford Maverick Is this bed cover installed correctly? 2025-02-17 07.20.17
Tbone289
I don't have this specific cover, but generally speaking you want the tonneau and the seals to extend back to where they're overlapping and sealing with the top of the tailgate.
Appears to be installed to far towards cab. I have different one installed on mine does not leak but there is only about 1/2-5/8" overlap onto cab and tailgate.
Jeff D.
Duluth, MN.
Dana, I have that same cover and that is the way mine looks, also.
DanaL
Dana
Rhode Island
2024 Lariat
Bummer... Not the answer I was hoping for, but good to know. Thanks.
olderthanyourdirt
so Cal
2025 Maverick
If factory installed, I would take it to the dealer. Hopefully enough wiggle room to eliminate or improve.
MikeS1942
Windsor Ontario
24 Maverick Lariat
I have the same cover and same issues. Went on line, and checked out the cure for this, and it works very well. Amazon had a 3M gasket and videos on how to apply. No dust and only minimal water issues after installation. Check it out.
DanaL
Dana
Rhode Island
2024 Lariat
Thanks for the heads up.
Can you give me more of a description?
There are tons of gaskets, even looking at truck bed gaskets.
Currituckkid
Mount Pleasant, SC
20244 Maverick Lariat FWD
I have 24Lariat with factory installed cover. I also have a slight opening at rear end. Mine appears to be adjustable inside the bed at the front end. I intend to see if it can be moved back a 1/2 inch and still remain sealed up front. My salesman pointed it out that it may be too far forward. I had appointment with dealer but had to cancel. Will have to reschedule.
Bobby Chapman
Bobby
Orlando fla.
2023 maverick
My factory installed ford tri-fold looks like it is to short as well.
DanaL
Dana
Rhode Island
2024 Lariat
That is the consensus. It's so weird that Ford can't make a cover that fits. I'll try to figure something out.
Thanks
Bobby Chapman
Bobby
Orlando fla.
2023 maverick
Thanks
We would think that Ford engineers could get measurements correct.
It is just like the rear axle Not being in the center of the wheelwell.
Ford Maverick Is this bed cover installed correctly? 20240527_105516
Ford Maverick Is this bed cover installed correctly? 20240527_105452
Ford Maverick Is this bed cover installed correctly? 20231123_114537
REMUB40
Fredericksburg, VA
2018 Honda CRV
I had my son climb in the bed and loosen the bolts. I adjusted to back to the tailgate and held it in place while he tightened everything back up. It will never be completely waterproof, so I do get a few drops in there.
KirkyMav
Jamie
Austin, TX
I have a Leer on mine that overhangs the tailgate a bit more and looks like it seals to the sides of the bed differently too. It does not leak.
Ford Maverick Is this bed cover installed correctly? IMG_4681
Buckgrafix
West Kentucky
2024 Ford Maverick Lariat
I have the same factory installed hard roll-up bed cover and it looks exactly the same. There's apparently no way to have an entirely water-proof cover for the Maverick without the use of weatherstripping. It hasn't been an issue for me though because any water that does enter seems to drain immediately near the leak points.
