Inverter: modified or pure sine wave?
Decayed
yes
a car
Anyone know if the inverter option is pure sine wave or modified? Since they don't specify which it's probably modified but you never know.
Big_T
T
2022 Maverick XL Hybrid
I'm gonna say it's NOT pure sine wave based on the limitations in the owners manual.
Ford Maverick Inverter: modified or pure sine wave? inv_1
Decayed
Decayed
yes
a car
That basically says "not pure sine wave"
CessPilot
Jerry
New Mexico
05 F250 SuperDut
What is the problem with plugging in a small refrigerator that draws .63 amp on AC 120 and 6.5 amps on DC 12v? I have not been aware of the modified sine wave with the 120 plug and have used it several times for 10-12 hours at a time in my Lariat Lux package. I am using a Dometic CFX 28 portable refrigerator.
Exranger
Northern California
Most of those things listed have high startup load, exceeding the limit. Who has a scope out there, it will show. Maybe your fridge is low enough load to run.
CessPilot
Jerry
New Mexico
05 F250 SuperDut
I have in the past plugged the refrigerator into the 12 volt cig. socket in my F250 Diesel and it sometimes burnt the fuse. I bought a solar powered lithium battery/generator and the first time I used it and plugged into the 12 volt plug, it drained the battery in about 8 hours on a 10 hour trip. Since then I have pugged into the 120 circuit and in 10 hours only about 1/2 discharged. Since then my Maverick Lariat arrived and I just plugged into the 120 plug in the bed with no issues I use the fridge for hunting and fishing, however my wife likes her cokes cold when traveling and in the motel, so I use the Maverick to travel.
Decayed
Decayed
yes
a car
It will power a crock pot-)
Only if it's under 400 watts. :)
I've run a laptop off it no problem since the charger re-inverts to DC. Since I posted this thread, I got my truck and tried to run an LED work lamp from it. The light flashed because of the power being dirty. Ford said it was an "incompatible lamp".
Nw_adventure
Salt Lake city
And most are -
LSchicago
Lloyd
IL
400w at 120V is about 3.33 amps.
johnny99
johnny
indiana
22 maverick lariat awd 360
I'm guessing some folks have swapped out for a pure sine wave version, rated at a higher wattage?
I'm not an electrical guy, but seems like it would be straightforward.
Jraoffroad
Ohio
2012 F150, 2001 F350 Diesel Dually, 2019 Kia Soul
  • Like
Reactions: bgn
WildGrok
none
1.33 amps on the lamp side (120v)
33 amps from the 12 side !!!
(that's a lot of amps)
