Intermittent no power isuue
YOBY
Yoby
Pa
2016 RAV 4 / 2022 Maverick Lariat
Sounds like just a loose battery cable, I'd check that first.
In all my years, I have never heard of so many loose battery cables. The biggest concern in the past were corroded clamps. Guess I better look at mine today.
Chris_G
NOVA
C-6 Corvette
YOBY
Yoby
Pa
Issue seems like the Hybrids problem? Yes, No?.......
I know from experience if your don't overdesign the relays going into these Hybrids, you're going to have failures. My maverick is clicking relays like they have a little band playing under the hood. Unless they have thick silver contacts, they will burnout and fail in a few years.
Because of the uncertainty of the new hybrids, I opted to get a extended warranty for the first time in my life.
Scupking
2025 Ford Maverick XLT Hybrid
You figure Ford would know how to build a hybrid by now since they have been making them for almost 20 years...
YOBY
Yoby
Pa
It's not a car anymore, it's a computer with wheels. Top shelve components cost a lot of money in the Electronic Industry.
We have been using brakes on cars for over 100 years and now we have intermitent issues.
Get a Prius and copy the whole car drivetrain and build it under license from Toyota. Take small steps instead of trying to bring EV's to market without proper evaluation and testing.
Milous
WA State
2022 XLT Alto Blu, LUX, Sunroof, delivered 3/18/22
The factory manual shows this image for one of the hybrid battery cables ("Battery Cables - 2.5L Duratec – Hybrid (121kW/164PS) (S3)" :
Ford Maverick Intermittent no power isuue Maverick_Battery_Cabl
Anyone have any idea if this is the cable with the bad solder connection? It does not appear to match the LX6Z14290PA cable.
Scupking
Milous
WA State
I believe this is the bad cable
I wonder if that one runs from the battery to the engine compartment? The image I posted has the end terminal (#2 in my FSM photo) that someone mentioned was the one with the bad solder ("position B" in their photo showing "A", "B", "C").
On the hybrid inverter/controller it's designed to specifically mitigate this by first charging a smaller capacitor that requires less current to minimize arcing and balance the voltage on both sides of the contactor before connecting the three larger capacitors.
YOBY
Yoby
Pa
It requires more than a capacitor to save the contacts. You need the time-tested RC Circuit to stop the arc and a resistor to limit the inrush current that can ruin contacts. It all gets down to space and how many components you're willing to invest in for a sound design.
Ckisela
Sacramento
2022 Maverick XLT Hybrid
After only 50 days in the shop the saga is finally over.
Ford shipped the part faster than expected, service put it all back together, tested it and gave me a call to let me know it was ready. I took it out yesterday and the truck performed exactly as it should. I hope all the other hybrid owners that run into this issue get a quick fix since this now seems to be a known issue.
Aza
DFW
So glad you got it fixed!
