FDT93
Jason
Hyundai Elantra, Tucson, 1986 Merkur XR4Ti
The months of waiting for my truck to be delivered was spent reading about other people's experiences on this forum. There seemed to be enough complaints or anecdotal evidence of how easily the paint seems to chip or get damaged. So, I decided to invest in one of the hood protectors to protect the leading edge of the hood from rocks and other highway debris.
I chose the one from WeatherTech because I like the company. The installation was easy enough to do. And the Maverick hood is small enough that I had no trouble installing it without help. Reading through the instructions and watching the short video beforehand made the steps easy to understand and follow.
The before shot:
Ford Maverick Installing the WeatherTech Hood Protector IMG_20220403_160611311_HDR
I washed the front of the hood using car wash detergent and a microfiber towel. I then dried it with another microfiber towel. I then set the protector in place. I applied masking tape at the top edges of the protector while holding it in place with my hip. I stopped multiple times to make sure it was in place and hadn't slipped.
This is after masking:
Ford Maverick Installing the WeatherTech Hood Protector IMG_20220403_161305280_HDR
Two alcohol pads are supplied. I used one pad for each half of the masked area concentrating on the edges where the adhesive strips will contact the hood. The alcohol dried quickly. I then used the supplied prep pad to wipe the same edges in the masked area. It would be a good idea to use gloves to apply the prep solution. When I was done, I immediately had to wash my hands to get the solution off my fingers.
After I removed the masking tape, I prepped the adhesive strips by pulling two inches of the backing and folding them over so they stick out when you set the protector on the hood. For each strip, you start in the middle and pull the backing to either side.
The next pick was taken after I had already pulled the top and bottom center sections of backing. You can see the backing for the edge sections still waiting to be pulled:
Ford Maverick Installing the WeatherTech Hood Protector IMG_20220403_162336153_HDR
As long as you apply light, even pressure, pulling the backing is easy. And you always start from the middle and pull towards the side. Once each adhesive strip is exposed, I applied pressure all around the protector starting from the middle and working outward.
I then carefully removed the protective film.
The finished product. It is recommended that you do not drive for 24 hours or wash the truck for 72 hours, so schedule your time accordingly.
Ford Maverick Installing the WeatherTech Hood Protector IMG_20220403_162533070_HDR
Ford Maverick Installing the WeatherTech Hood Protector IMG_20220403_162542375_HDR
Ford Maverick Installing the WeatherTech Hood Protector IMG_20220403_162557248_HDR
bwayne
Bruce
Missouri
2015 F150, 2008 Edge
So it doesn’t stand proud of the hood like the old style bug deflectors?
Mymaverick2021
Steveo
Hilo Hi
The before shot:
Well if you gotta drive keep it under 70🤣
Fragmental
Lawrence, KS
2022 Ford Maverick First Edition
It looks glossier than the one Ford sells, does that seem to be accurate? I was going to get the WeatherTech myself, but I'm not in love with that glossy look.
bighap
Oregon
2023 Maverick Lariat Hybrid
Does the WeatherTech logo come off?
jwiedle24
Ohio
Lariat w/Luxury Pkg
Wonder why they can’t just make a clear version
mistere213
Josh
2022 Maverick Hybrid Limited
If I had to guess, it's because anything clear plastic that gets exposed to sun often goes yellow pretty quickly and then just looks nasty. Where dark colors and tints just tend to fade a little over time.
BoboysTruck
Virginia
F150, Focus, Juke
Ford one is glossy too. Actually, they look exactly the same so I wouldn't be surprised if Weathertech is a rebranded LUND AEROSKIN.
EugDom
Geno
Johnstown
Jeep renegade
Ford sells 2 different types. Smoke, which is glossy like the one you see posted from OP. Textured, which is flat black and not see thru or transparent in any manner.
FDT93
Jason
It doesn't look like it would come off easily. It doesn't really bother me enough for me to risk making it look worse trying to remove it.
New England Aaron
aaron
Boston
Ford Maverick XL
I should consider one, I already have a little chip in that area.
NorthShoreMaverick
New York
Ford Maverick XLT
I have a gift card for weather tech so this may be my purchase as I was trying to figure out what to use it on!
bwayne
Bruce
Missouri
