I ordered the Lund deflector from the accessories site back in March, but it got lost in transit. The WeatherTech deflector seemed like a decent replacement. I just finished installing it.
I would get it to prevent the chipping. It will also prevent bug guts at least on the hood front. I order one from RealTruck.com. The install uses plugs that already exist that hold the foam insulator in place at the front under the hood. There are also some clear rubber feet to use so the wind doesn't bounce the shield off the hood. It does take extra time for the paint to totally cure. 60-90 days? And I am not sure if the chipping was from paved roads or Dirt road drivers. That would be good to know.I'm kicking this idea around while waiting for the dealership to have my truck ready.
What are the main benefits? Prevent rock chipping on the hood?
Does it create hood shake at high speeds?
Is there an adhesive to mount this? Wondering if that would be a problem for car washes or when you remove it?
There's a build out there somewhere with the bolt on option that uses existing holes under the hood...just have to comb through the posts...Is no one concerned about the 3m tape directly on the paint? I've used the 3m tape in multiple applications, and over time it's just ungodly trying to remove it. Since you can count on these deflectors to wear out / need replacement after several years, I anticipate a helluva problem getting the old tape off, without damaging the paint. I'd rather have a bolt on option -- love Weathertech, but they don't seem to have one?
Earlier on this thread someone mentioned a bolt on hood protector available from RealTruck.com. You might want to check that out.Is no one concerned about the 3m tape directly on the paint? I've used the 3m tape in multiple applications, and over time it's just ungodly trying to remove it. Since you can count on these deflectors to wear out / need replacement after several years, I anticipate a helluva problem getting the old tape off, without damaging the paint. I'd rather have a bolt on option -- love Weathertech, but they don't seem to have one?
Other than a lot of elbow grease, goo be gone, and WD40 (best for removing 3M tape), I've never experienced a problem removing 3M tape. It is damn sticky stuff though Always treat the area with a little Mirror Shine afterwards.Is no one concerned about the 3m tape directly on the paint? I've used the 3m tape in multiple applications, and over time it's just ungodly trying to remove it. Since you can count on these deflectors to wear out / need replacement after several years, I anticipate a helluva problem getting the old tape off, without damaging the paint. I'd rather have a bolt on option -- love Weathertech, but they don't seem to have one?
Orange Goo Gone works wonders for the 3M tape residue.Other than a lot of elbow grease, goo be gone, and WD40 (best for removing 3M tape), I've never experienced a problem removing 3M tape. It is damn sticky stuff though Always treat the area with a little Mirror Shine afterwards.
