I can turn radio on without key fob
DadsLariat
SouthEast Wisconsin
2024 Mav Lariat Hybrid, 2015 Hyundai Santa Fe
I have a 2024 Lariat Hybrid. (Push button start). Sync3 radio system.
I was trying to fix a dash rattle (see TSB 24-2317) instead of taking it to the dealer. My keys were in the house (so not on Run or Accessory). My drivers door was open and my arm deep under the dash. My head must have leaned on the radio volume button. All of a sudden, my radio was on. Opening or closing door does not shut off radio. I need to pust the volume button to shut off radio.
I can re-create this situation at will now.
1) Do not have key fob with you.
2) open driver door, get it. Leave door open or close it.
3) push and hold volume button for a second or 2, radio comes on. I get AM, FM and SiriusXM
(May need to push volume button a second time to get media screen to appear)
4) open, close door. Radio stays on.
5) push volume button to turn off radio.
What the heck. isthis part of the battery drain. (Besides SSM 53801)
Can anyone else do this ?
saffrontruck
Eugene, Oregon
2022 Maverick XLT Hybrid
In my '22 hybrid XLT, I can turn on the radio when the truck is off, and it will stay on for 30 minutes. Probably a Forscan thing?
Hot Runr Guy
West Chicago, IL
Not just a Hybrid thing, can also do with my '24 Lariat EB.
HRG
Great to know!
When it appears my 12V battery isn't dying soon enough for a well timed warranty replacement - I can help a little and walk away.
I could see this becoming a parasitic drain - another item that could accidentally be running when you think power is off and it should not be.
Sometimes the manual - what?!
Switching the Audio Unit On and Off
Ford Maverick I can turn radio on without key fob {filename}
Note: You can only switch the system off when the ignition is off.
shipmack
SE MI
2022 Maverick XLT Lux Pkg 4K COPilot360 Area 51
Found this when I was driving my 2013 Fusion. Can do it in my 2022 Maverick. Can do it in my wife's 2021 Chevy Equinox.
Probably an industry wide feature.
nobes
nobes
United States
Ford Raptor
read more at Pompey News
This seems to be an issue with the Sync 3 system, where pressing the volume button while the door is open triggers the radio to turn on even without the key fob. It could be related to a software glitch, and while it likely won't cause significant battery drain, it might be worth getting the vehicle checked by a dealer for a software update or further investigation. Keep an eye on your battery, but this behavior is not typical and may be fixed with an update.
dalola
Retired
SE Ohio 🇺🇸
Nope, this is exactly how it is designed to function. The BMS will shut the radio down prior to excessive discharge levels.
Escapologist
Niagara Region, ON
My Escape keys will open the trunk from a block away.... so I keep them in a tin to avoid aiding miscreants with semi-functionality or signal boost/relay for proximity spoofing.
Have you ever tested if they indeed do what the manual says - goes to sleep when not moved?
Saves the fob battery.
Set on table in garage near the vehicles for several minutes non-moving, attempt the keyless entry.
Of course if this isn't keyless - never mind. Those don't send out a signal until a button is pressed anyway.
Kenv24
Ken
2024 XLT
The windows will work also...after you take the key out....as long as you don't open and close the door. You can open the door and still move the windows.
KenE
Ken
Mount Washington, KY
2025 Maverick Hybrid Lariet
Yes. It's been a Ford feature for years. I could do it on my 2016 F-150, so nothing new on Maverick. It requires no Forscan intervention. However, Forscan programming changes to configure our Mavericks and other Ford vehicles for many other features is fantastic.
Have you noticed a time limit?
Rav4 had a time limit to adjust them.
Even radio shuts off eventually. Well, that could be my low voltage too, so battery saver timeout.
KenE
Ken
Yes, there's a default time limit, but don't recall what it is in the Mav. My 2016 F-150 was set at 20 minutes, but I changed it to one hour with Forscan. Haven't bothered to see if radio timeout is changeable on Maverick with Forscan.
