ThisMight want to edit that title. Sure sounds like you repaired the battery, not the wiring harness. At least that was my thought.
Ha! I have that exact same lug in my pocket right now. I got it after watching a YouTube where the guy, a Ford technician, repaired that crappy, soldered connection to the battery. This wiring harness issue is just lousy terminations. The YouTube I saw is:Ok, heres the repair for the hybrid battery cable fiasco. I have my own repair, now that we have seen so many repair fails, and we understand that the vendor doesnt even know that they are producing defective cables YET!
I use a copper clad lug, oh wait we are working with aluminum cable so there is no copper involved. So no need for copper or clad, cause i have an aluminum lug.
No need for huge crimpers here, just install, torque, wrap with tape, touch of Deox, and wham-o, call it done, rest at night knowing your Mav has a #1 professional repair.
If you are in central Texas, let me know.
Ha! I have that very same lug in my pocket. I got it after I saw a YouTube of that connection problem. It's not the harness, it's that shitty soldered cable to plate. Here's some other lugs I've used.Ok, heres the repair for the hybrid battery cable fiasco. I have my own repair, now that we have seen so many repair fails, and we understand that the vendor doesnt even know that they are producing defective cables YET!
Wow, Tim, if this is true, it kinda changes everything. It makes so much more sense that the harness is stranded tinned copper wire. It always bothered me that Ford would design this hybrid using aluminum. So, apparently a copper lug will do the trick. Go figure.Pretty sure the wire is tinned copper and not aluminum.
