- First Name
- Mike
- May 3, 2024
- KC Metro area
- 2005 Toyota RAV4, 2024 XLT Hybrid
- Engine
- 2.5L Hybrid
Ok, it does not always. Thinking amount of brake press may matter.Thanks. Nice to see.
I would like to see HV SOC on the same chart.
Also does brake pressure always go up at 11 mph or just in this case? Do you have multiple examples?
I don't recall what was going on here, maybe a red light going green with traffic, because I didn't have to stop completely as brake pressure never came on and brake was let go at 5 mph, but almost coasting to 0. So no
Had been slowing from 29 mph, ICE was on because below 40% SOC.
Maybe brake pedal being 1 mm or less mattered.
Here's another same trip.
From 25 mph braking to a stop, ICE on below 40% again.
Amps higher with ICE but still in regen, brake pressure started at 11.2 mph. Brake pedal over 1 mm. Still not upwards of 3mm a hard press comes in at.
This is the full stop info - dug into pads for whatever reason initially, but backed into total regen again with no pressure applied at 18 mph. Until that 11.2 mph auto-pressure overlap with regen. The max brake pressure at 5 mph had pedal at 0.8 mm from then on. Was actually at 1 mm at 7.5 mph.
