How to disable TPMS?
Aech40
Pennsylvania
2023 XLT
I got a set of XL steelies to serve as winter wheels for my XLT hybrid. They didn’t come with sensors and I just put regular valve stems in them because I really do not care about sensors in the winter wheels. The warning message that the system is faulty is the most annoying thing about this truck (it beeps, it flashes). Any way to disable the system for the winter? I know its a government mandate so it’s probably a tall ask but the truck freaking out every time I drive it is pretty lame. Thanks in advance!
ryan2366
Ryan
2025 Maverick Lariat - Hybrid AWD
if you are familiar with Forscan you can disable the TPMS menu in the IPC module.
Turn it back on when you change your tires.
Ford Maverick How to disable TPMS? IMG_0564
Aech40
Pennsylvania
2023 XLT
Not familiar with forscan but I will look into it. Thanks!
TPMS is a useful technology. I don't view it the same as wearing a seatbelt for safety, but I would suggest to just go get TPMS sensors installed.
It really doesn't matter if it's "only" your winter tires. You are using them the next several months, and a slow leak that TPMS would have caught will still ruin your day.
Aech40
Pennsylvania
2023 XLT
There’s several reasons I didn’t go with TPMS:
Cost
Its a pain in the butt
I keep the tire gauge in the truck at all times, and I do at least give a visual check every time i drive.
For the winters, it doesn’t really matter to me. This is actually the first car I’ve owned that has them installed. Its more an annoyance than an actual useful feature , at least in my experience, IMO. I understand why someone could like it but respectfully agree to disagree!
Mavericksport
Peter
Connecticut
What did people do before TPMS sensors? There a waste in my opinion. $200 at the tire shop installed.
Aech40
Pennsylvania
2023 XLT
For real. Its not like I was asking if I should get tpms sensors, I was asking how to circumvent them lol
This is somehow both a good question, as well as a really dumb question.
The primary reason that TPMS was invented and subsequently mandated by the US and other governments is a high number of fatal accidents where low tire pressure was noted as a significant factor in causing the crash. Ford Explorers with Firestone tires were the scapegoat for this. It happened with a lot of vehicles, but lawyers got involved and smelled the money, and they got it.
TPMS can warn a driver of a slow leak, and it can provide definite confirmation of a major puncture or blowout so you can get off the road as soon as possible.
Specific to a Maverick, TPMS is particularly useful because it can be seen in FordPass and it warns. If you get the low tire pressure warning, you can look to see if it's just slightly under (I think 28 psi causes it) or if it's nearly flat.
There is no question it's on a human to ensure that the tire pressure is good and the vehicle is safe to operate. TPMS makes that easier to do.
raymaines
Ray
Tacoma, Washington
Alto Blue Lariat Lux Hybrid
Cost
How is the TPMS a pain? Besides in the wallet anyway. You don't have to look at it, it's just there. Totally unobtrusive.
Aech40
Pennsylvania
2023 XLT
Until you have a sensor go bad. Every car has a different frequency, its just annoying. I had em in my civic and they leaked, and they went bad intermittently (and this was after replacing them). Its far less of a hassle to just keep a tire gauge close by. I also have a ryobi inflator that i take with me so the slow leak thing is virtually a non issue.
raymaines
Ray
Tacoma, Washington
You're your own man and can do whatever you wish, but I've got at least as many miles under my belt as you and I've never had a defective TPMS.
Aech40
Pennsylvania
2023 XLT
Yeah man, I know what I got myself into lol. Simply wondering if there was a way to turn the stupid light off.
hdave
Toronto, Canada
'23 Alto Blue Maverick XLT
I agree with OP - Wish there was a way to disable TPMS.
realshelby
Houston
1969 GT 500, 1965 Mustang GT,
I will give one good reason why TPMS are not the Holy Grail.
Part of my driving pre trip is looking at my tires. Not just to see if one is low ( you develop a sense for how they look when properly inflated) but to visually inspect them for a nail, tread defect developing, or any obvious defect that may be a problem sooner than later. I double check my tires about once a month with a gauge. Yes, I have TPMS in some of my vehicles, but the only thing I consider them good for is to alert to a tire going down at speed. If a catastrophic blowout....they are no help. But a slower leak they might be, although you can often feel that in how it drives.
commadorebob
Solution above. You will need Forscan.
I personally like the TPMS. I still use my Ryobi pump to ensure tire pressure is where it needs to be, but the TPMS has helped in the past to let us know when we had a screw in the tire. Given I work from home, a slow leak could happen over several days before I visually notice.
