How much should the battery lose when parked?
pulledpork247
Stephen
Calgary AB
2024 XLT FX4 LUX Ecoboost
I have a 24 Ecoboost with a parasitic drain issue. When I park i have about 98% battery. When I get up to go work I have about 60-63%.
How many percent should it drop overnight without a parasitic drain?
Tbone289
MO
I can't tell you in terms of percentages, but I can tell you that my '24 Ecoboost only draws about 10mA after systems power down.
So is that SOC reading Ford's special SOC from a scanner, before you click key to On in the morning, or from another device measuring Voltage and like table lookup for corresponding SOC%?
They can be vastly different - it's why morning resting voltage is more important to note.
The external device giving you a SOC% lookup from a voltage reading, after you've just been charging it during your drive - is a bogus voltage reading for purpose of SOC lookup or battery health.
Inflated value - don't use it for anything.
Ya, it'll drop hugely in like 4 hrs too.
But if this is Ford's special SOC, which is calculated from initial resting voltage and tracked while you drive for an ongoing SOC% - that would be a normal 2-4% drop from posts several have made.
Depends on if you got a really long drive and good high charge & SOC% - but battery can't hold the charge so it drops more.
pulledpork247
Stephen
Calgary AB
Hey, I've been using an Autel battery tester. When i leave battery disconnected at night it stays at 98%. Only drops when connected to the vehicle. I'm gonna be taking it to the dealership here in the next week or so to get it looked at. Just trying to figure out as much as I can before hand!
So that's considered a table lookup.
This voltage = this SOC%.
That's all.
If you give the tester a battery Ah spec - when it tests the result is used in the SOH given.
So when you do the test or get that Voltage reading very much matters.
And you didn't answer that question.
If it's had a charge within the last 2 hrs - bogus don't even bother acting on the reading.
So if that 98% was after a battery charge while disconnected from truck, and then you just disconnected the charger say and got that reading - bogus.
If you come home from a drive and test and get that 98% reading - bogus.
If you test again in the morning and get 60-63% - valid.
Again - true Volt reading would be better info to log.
And what you need to provide the dealership - true reading, not inferred.
Because the battery does hang out at 12.5 abouts by design of the BMS charging strategy - which on some tables could be considered 60% on low end.
You could indeed have a parasitic draw - but unless you give them some valid figures from good testing - they are unlikely to spend the required hours on it trying to track it down.
They'll charge it up before they leave. Let it sit overnight. Get a reading the next morning, and load test it. And they are unlikely to spend that time if you pull in and they test it high enough.
Just trying to save you the waste of time - since you have the tool to get some valid figures.
Way to test for the desired voltage reading.
Get done with drive.
3-4 hrs later before bed - get a reading.
Get another reading in the morning.
That's useful info to provide.
Tim d
Alpena
Ram
That seems excessive, our ram sits for 3 weeks sometimes and the battery is fine. I have an antique that routinely sits over a month and the battery is fine. Our maverick has sat maybe a week without use, But the battery is fine.
jmatchco
Colorado
21 BMW X3 M40i, 07 Honda Fit
Can't answer your question, but I may have the cure. My battery kept draining due to my low-use and short drives, and the truck kept going into deep sleep in the garage. I disabled every communication/telemetry option I could from the driver's seat (menu options only, I pulled no fuses), and it's been fine since.
Since the only way to know about Deep Sleep Mode is the alert received on the Ford app, which requires the modem connected to send the change of state - curious if you still have the battery saver functions like lights off quickly on entry/exit.
Those start kicking in at 12.1 V, whereas DSM is much lower.
smoreho2
Virginia
2023 XLT Hybrid (October 2023)
I just put a new AGM in my 23 hybrid XLT, and it is doing fine. I think my next one will be something like this that monitors itself!
https://a.co/d/09aLJGhr
jmatchco
Colorado
I should have clarified: I think it was in deep sleep because the dome & dash lights didn't come on when I opened the door; I didn't check the app. Even after a 30-min drive to the dealer, they reported the battery was low on charge. I don't recall any other battery saver actions.
Lights is the battery saver functions.
Bad enough, the passenger keyless entry sensor will be disabled.
Though not reported, maybe the driver's can get to that point too. In which case radio for keyless entry can be disabled also.
Modem being disconnected is the only action on Deep Sleep Mode.
Nice find - even the right size!
Does make me wonder how the BMS would read it - to know which charging strategy to use with it.
And would the built in shunt and BMS confuse the truck's sensor and BMS?
The only kicker is the CCA don't matter a whit for Hybrids closing a relay - but longer Ah and RC would be.
At least that type of battery can handle those micro-draws better anyway.
Mavster Mechanic
Hybrid
Do not put a LiFePo battery in your Ford truck. High probability of fire. It is not compatible.
With your new AGM keep it heathy for 7 or 8 years, maybe more by programming your parking lights to be full time running lights.
It's probably a fluke, but it works.
You may never have to buy another battery.
smoreho2
Virginia
Thanks Mavster. My AGM is working great. I was glad to get rid of the oem battery!
Nuvolari
Charles
Iowa
2023 Lariat Hybrid
Drove my '23 50 miles. Parked in parking lot for an hour. Drove across the road to another parking lot. Half hour later, no start and 7 rolling codes on the dash. Started it with a jump box and drove it to the dealer. Sold it back to him. New Toyota SUV arriving today or tomorrow. Fartley can keep his consumer experiment.
