Hood vibrations
Rodog800
Noah05
2019 blazer
Ok just drove out to Ohio this morning to get my FE. Been driving all day and have noticed the hood vibration near the windshield gets all over over 70...anyone else . Has anyone took to dealer , thoughts fixes...never have seen this on a car ever
Brian_J
Akron, Ohio
'22 HPR Maverick AWD 4K LUX
Check out the other post on this same issue for info on how ford fixed it on f series trucks
brnpttmn
MN
Read the title to the tune of...
Headdead
Birmingham, Michigan
Boxster S
Mine only has 200 miles on it, so I have only touched 70 mph for a short time, but I did not notice anything unusual (AWD, 2.0l). If mine develops a vibration I may try adding a local stiffening patch (Dynamat or something similar.) Check that the hinge bolts are still tight.
Update after 500 miles: no vibrations below 85 mph. Haven't looked higher. Yet.
Rodog800
Rodog800
Noah05
2019 blazer
I will when we get home was the plan
pxpaulx
Minnesota
Anymore info than that have a link?
Mine is doing it absolutely. I do wonder if it is more noticeable depending on your vehicle color...
bgillen35
Brendan
St. Cloud, Fl.
'24 Maverick XLT, '22 Indian Chief
bgillen35
Brendan
St. Cloud, Fl.
At least on the F-150s, it has to do with air pressure causing the hood to flutter, nothing to do with the hinges. According to that service bulletin, you need to adjust the latch tighter or put rubber hose under the front of the hood to create an air seal so no air gets under the hood.
pxpaulx
Minnesota
Interesting I have the lund bug shield installed yet 2 weeks ago o test rode my same build with no bug shield still a flutter in the hood...maybe the F150s issues is the same as this
Does that shield adhere to the hood, or is it more traditional where it has clips under the hood?
Hammer
Easton PA
2009 VW GTI
I test drove a Bronco Sport with the 2.0 EB back in January and I noticed the hood flutter on that vehicle during my drive. I ended up not purchasing the car ( I liked the driving qualities but thought the rear interior space was small, plus the dealer was adding $3k market price uplift for the new model ). I found the hood flutter to be annoying but forgot all about it until I started reading the MTC reports about it occurring on some of the new Mav’s. I hope there is a fix if it happens on my Mav.
