Help - Trailer Ball Mount Question
Barracuda340
Abilene Tx
If you get the first hitch you can always flip it around.
I picked up one of those like the one in the first pic, I will likely flip the ball around. My trailer is an old converted dodge dakota pickup bed into a trailer. Maverick may end up sitting too low for it. But then again my silverado has a 2"-4" drop on it and sits just right with the trailer.
Ford Maverick Help - Trailer Ball Mount Question 20200104_094619
commadorebob
I have a 5" rise/drop for my Saturn that sits 12" to the top of the receiver. So, that would be about 17" total. I used that for a pop-up camper that had an offroad kit so it tended to sit higher up than my father-in-law's Seadoo trailer, which I used a 2" rise/drop for.
Part of what you need to account for is the amount of play in the spring based on the weight on the tongue (hence my 5" drop for my camper).
Get a rise/drip that isn't welded. Simply for the unexpected flexibility.
Optimus
MN
2023 XLT Hybrid
In my case, I went with an adjustable height aluminum hitch. A bit more pricey, but then I can put the ball at whatever height I need to. It also has two different size balls built in. I confess, I do have different trailers and even different vehicles.
One hitch to rule them all.
V-blue Mav
Missouri
2014 jeep Cherokee and 2006 F-150 2022 Maverick EB
FWIW, MY 2006 F-150 4x4 receiver hitch is almost an inch lower to the ground than the one on my XL Maverick AWD. I'd just wait until you get the Maverick before you buy anything.
Actually it's a wash. Neither are sitting on pavement so there's that factor.....
Ford Maverick Help - Trailer Ball Mount Question IMG_20221002_161308254_HDR
Ford Maverick Help - Trailer Ball Mount Question IMG_20221002_161341102
FriscoTXJoe
2022 Maverick Lariat
I just jumped in to learn about the trailer ball I need to get and I just wanted to say:
"You have a very nice trailer."
bwayne
Bruce
Missouri
2015 F150, 2008 Edge
I'd wait and once you get your truck (whenever that is! :)) then do the measurements that @Maverick2022XL describes. You always want your trailer level or slightly above level at the tongue., never lower at the tongue.
I have read that you want a tongue weight of 10-15% of trailer weight to minimize sway. Check out this video.
CSmith
CJ
Southern Indiana
2022 Maverick XLT FX4, 2020 F150 XLT FX4
Exactly right! If you are pulling a trailer with a load of 2,000 pounds you only want 200 pounds on the hitch. That is why it is important to make sure your hitch ball is at the right height to "level out" your trailer. If the ball is too low then you are putting more weight on the hitch than you should and that does not include how well you balance your load. A lot of factors to consider when towing.
